Cab Mount Bushing Replacement
Old Aug 31, 2009 | 08:56 PM
dancer's Avatar
dancer
Hi,
I've searched the archives and there is a ton of info on this but nothing
I could find about how to do the job. The fronts are straight forward
but it appears that it is necessary to remove the gas tank to do the
rears Please tell me I'm wrong about this but I don't see any
other way. I have a new bushing and hardware kit from D-C.
Thanks,
Carl
'71 F100
Old Aug 31, 2009 | 09:54 PM
Ford_Six's Avatar
Ford_Six
On my 72, It appears the tank ledge is also where the cab mount bolts go, sorry.
Old Sep 1, 2009 | 04:31 PM
19704X4F250's Avatar
19704X4F250
Carl, yep, the tank has to be moved up. It is easier if you remove the seat, remove the filler, remove the gas line and remove the straps. Then block the tank up with 2 X 4's. You now have enough room to get a ratchet in there.
Old Sep 1, 2009 | 08:06 PM
dancer's Avatar
dancer
Thanks Scott and Dan......you know i really needed somebody to just
hold my hand on this issue. So the seat is already out being upholstered
and now I'll just get on with the rear cab mount bushings.
Carl
brentkhack
Oct 30, 2016 10:07 AM
Fordication
Apr 15, 2016 10:59 AM
BuddyFord
Sep 26, 2006 07:21 PM
BTW
73
Dec 5, 2003 04:48 PM
cccc1
Apr 20, 2000 07:22 AM
