I recently purchsaed a 6.0 litre powerstroke diesel Excursion and the having several issues can anyone help?
1) Took to ford dealer and they truck has rough idle they stated needed a #1 injector we replaced and still has same issue. Acts like it has a miss and want to surge @ 1800 RPM...Also, at times losses all power or has low power especially at first start up...
2) Replaced fuel filters checked pressure and had computer reflashed with latest programs at ford dealer.
We"ll you do have a 6.0 so your bound to have issues, and you obviously are, I would check to see if there are any codes, check your FICM, IPR and ICP sensors, Have you done the EGR delete mod, and studded it? the head bolts will eventually crack.
Have not done anything but had dealer flash updates to computer and today had my diesel mechanic install new fuel injector today...still acts like has a small miss in a cylinder.
Like I said, check your FICM, ICP and IPR, which injector did he change? It may also be your Cam Postion sensor or Crank position sensor.
