Excursion with 6 litre diesel
Old Aug 31, 2009 | 08:41 AM
Stillen GLE's Avatar
Stillen GLE
Originally Posted by jdadamsjr
oui vey ......
So much misinformation.... bound to have issues ?
the head bolts will crack ?!?!!? That's a new one I've not heard in 7 years of owning 6oh's...
to the op do go to the 2003-2007 6.0 section there was someone that posted about the same thing recently...
some suggested trying to disconnect ICP sensor IIRC? And others said it was injector...
Sounds like your mechanic did a half way job on your repair, consider returning and asking them why did that not fix it.... or go elsewhere ....
what area are you in ? maybe someone can suggest a good repair facility...
How is that misinformation? it is common for the headbolts to stretch, if that weren't the case people wouldn't be switching to studs.
Old Aug 31, 2009 | 10:51 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by autotoyzllc
they didnt give any codes but, retreived DTCS performed KOEO self test performed power balance test recalibrated control
Where do live? There is a Roadside Help Network that should be able to get you back up and runnning.
Old Aug 31, 2009 | 11:26 AM
Sarge261's Avatar
Sarge261
Would a Moderator please move this to the 6.0 forum so that we can help him down there without any of the your 6.0 is garbage replys happening and further frustrating the OP.
Thanks,
Sarge
Old Aug 31, 2009 | 11:38 AM
krewat's Avatar
krewat
Gladly
THREAD MOVED TO THE 6.0 FORUM
Old Aug 31, 2009 | 01:44 PM
npccpartsman's Avatar
npccpartsman
You need to have it scanned again for codes. Did the dealership install the injector or YOUR mechanic and are you sure he put it in the correct cylinder? #1 is passenger side front on a 6.0. How long has it been driven since the injector was installed? It may take some time for all the air to get worked out of the system before it runs perfectly. Lets take this a few questions at a time and we'll get it figured out. Sometimes 6.0's can have multiple minor problems that cause "major" issues. Loss of power at startup still sounds like an injector issue. Please be patient--forum diagnostics can take time.
Old Aug 31, 2009 | 02:01 PM
Stillen GLE
Thanks,
Sarge
I wasn't by all means saying the 6.0 was garbage I was telling him things to look into. Relax man.
Old Aug 31, 2009 | 02:47 PM
Sarge261's Avatar
Sarge261
I am relaxed and dont take things so personally. I could tell where the thread was going and thr OP was clearly getting frustrated. It only takes 1 misinterpretaion from 1 phrase to get the " you shouldda bought a V-10 or 7.3" thread rolling again.
There are too many of those, and besides he will get more help down here with us anyway.
So no hard feelings. If I came across a little harsh I appologize to everyone.
Sarge
Old Sep 1, 2009 | 03:01 PM
autotoyzllc's Avatar
autotoyzllc
6.0 diesel
Thanks for all the help....and someone just pegged the answer the diesel mechanic that came highly recommended replaced the #2 injector on the left side instead of the #1 injector on the right side..now they are saying the #5 injector is bad also, any suggestions...also someone stated a relay could be going bad?
Old Sep 1, 2009 | 03:02 PM
autotoyzllc
Correct the highly qualified (ha) mechanic replaced the #2 injector and not the #1 injector but, now they say the #5 is shot...and another person suggested a relay going bad..any help suggestions
Old Sep 1, 2009 | 03:08 PM
npccpartsman
My recommendation would be to take care of the injectors before doing anything else. Injectors can cause other problems, and yes it's possible to have multiple injector failures. I've had as many as 6 go out at one time (way back in the day though). An injector can be marginally working and not throw a code. It sometimes takes a GOOD tech with an IDS scanner to know how to find those weak injectors. It's better to do 2 at one time (1 and 5 are on the same (passenger) side) than to have to go back and do another teardown. I'd make the "highly recommended" mechanic pay for his mistake and while he's fixing #1 he can replace #5 at the same time. I would NOT remove #2. OR you can use the good injector he removed instead of purchasing another one. Still IMHO he owes you an injector.
When you get the injector problem taken care of and the truck is up and running THEN you can check for bad sensors or relays. Remember.........it can take quite a bit of time to get air out of the high pressure oil system to the injectors, so don't be fooled by a false code.
Old Sep 1, 2009 | 03:23 PM
autotoyzllc
Thanks for the help yes he is reasonable and only charging $200 labor since he made mistake but, i purchased another 2 injectors and will replace both as you suggested. Thanks
Old Sep 1, 2009 | 03:32 PM
npccpartsman
That seems very fair to me. Glad I could help.
Old Sep 2, 2009 | 07:46 AM
  #28
Sarge261's Avatar
Sarge261
Hopefully it works out for you. If you can find out what flsh you have it may not be the inductive heating flash. You may want to pay Ford to get that flash if you dont have it. Its supposed to help with some cold start issues and it also cycles the turbo during ildling to prevent sticking and a few other things too.
Sarge
joe blow
Mar 11, 2010 05:57 PM
autotoyzllc
Computer Chips & Tuners
Aug 31, 2009 05:42 PM
Snowking
Sep 2, 2008 08:36 AM
JoeVR5
Jul 4, 2008 07:47 AM
campster
Apr 19, 2002 03:57 PM
