Engine controller?
Old Aug 30, 2009 | 07:10 PM
Royson12's Avatar
Royson12
Talking Engine controller?
What is the sensor or whatever it is called. It is located top side of engine, center back of block. What does it control or what does it do. I know it has something to do with the glow plugs, does it controll anything else. Oh yea, it's a 85 6.9L 4x4 single cab bone stock. Thanks
Old Aug 31, 2009 | 01:50 PM
axe_handle's Avatar
axe_handle
Maybe post a picture?
Old Aug 31, 2009 | 05:41 PM
Mat J's Avatar
Mat J
glow plug controller and relay
Old Aug 31, 2009 | 05:56 PM
Royson12's Avatar
Royson12
I thought the glow plug relay looks like the old style starter selonoid? This thing is at the very back of the engine, has a lot of wires. I'll take a pic asap and post it.
Old Aug 31, 2009 | 07:07 PM
BombThreat's Avatar
BombThreat
I know my 93's has the glowplug controller unit right in the center back behind the air intake and firewall. Its the controller and a relay mounted right on it. But Im not too sure how the older glowplug systems are mounted or look like..
Old Aug 31, 2009 | 09:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
85 glow plug controller, screws down into the drivers side head almost against the firewall.
Oil pressure sensor, one wire right on top screws down into the block behind the intake but just in front of the adapter plate, almost center of the motor.
Although this engine has the 87 style glow plug controller, thing with a vented cover right behind the intake throat, you can see the oil pressure sensor above and to the right of the controller.
The plug where the old style controller would go is under the wiring harness though.
Old Sep 1, 2009 | 07:27 AM
Royson12's Avatar
Royson12
That's the jem I was talkin about! Thanks Dave. Does it just control the glow plugs, or something else. My glow plugs are hooked up manual with a push button. If it just controls the glow plugs, I'll leave it alone.
Old Sep 1, 2009 | 11:19 AM
Royson12's Avatar
Royson12
Ok, how do I test the glow plug controller? I guess I better hook it back up, seems my son doesn't know when to quit standin on the button. All my glow plugs are fried! so I better make it teenager proof. I pulled 2 glow plugs, one is split on the side, the other has a bead of metal on the end of it. neither have any ohms resistance, both are a wide open circuit. FRIED!
Old Sep 2, 2009 | 09:01 PM
Dave Sponaugle
The diagnostics for the old style system are about 2.5 pages long with picures to show what connections you should be testing.
I don't have them digitized so I can send them to you.
Does son have a job?
If so, let him buy your plugs, and I bet he figures out how to count to 10 seconds real quick.
Old Sep 3, 2009 | 06:27 AM
Royson12's Avatar
Royson12
Hey Dave, What book do you have that in? Might be inclined to purchase a book with good detail like that.
Old Sep 4, 2009 | 09:07 PM
Dave Sponaugle
You can find a diagnostic proceedure in the "Haynes Diesel Engine Repair Manual" book number 10330 at most auto parts stores.
Not the best book, but about on par with the rest of them.
Helm's is about the best, but they usually have a price that reflects that if/when you can find them.
Nicktitan
Dec 22, 2016 07:24 PM
Mikerage
1997 - 2003 F150
Jul 25, 2016 06:38 PM
jleeper
Aug 31, 2015 09:23 PM
mfp4073
1983 - 2012 Ranger & B-Series
May 7, 2015 10:25 PM
Brute440
May 5, 2015 07:39 PM
