Running Rough
Old May 21, 2002 | 09:17 PM
fordmon's Avatar
fordmon
Running Rough
Hello all,
I have a problem, i recently replaced the following Coil accel super coil, motorsport 9mm wires, accel cap & rotor, accel v-grove plugs and fuel filter. truck ran rough at idle and skipped then truck ran great for about a week now back to same thing. When i changed my plugs, old plugs were wet with fuel. 92 f-150 5.0 Jasper rebuilt motor with 10,000 miles. don't know if it's fuel or electric. so i posted on both boards. Any thoughts or suggestions would be helpful.
Old May 22, 2002 | 12:26 AM
Torque1st's Avatar
Torque1st
Posting Legend
Running Rough
For a first check pull the vacuum line on your fuel pressure regulator after the truck has been running. If there is any fuel in the vacuum line you probably have a ruptured diaphragm and will need to replace the regulator.
Please clarify the order in which the problems and events happened.
Old May 22, 2002 | 07:19 AM
fordmon's Avatar
fordmon
Running Rough
Hey Eric,
Thanks for the reply, I pulled and checked vac. hose to fuel pressure regulator nice and clean.
My truck started running rough, slugish and skipped at idle. So I replaced everything from plugs, wires etc. checked the timeing, the fuel pressure, vac-hoses and replaced any that either leaked or looked bad. Someone told me to run hotter plugs so I went with the Accel v-grove I was told their hot but not to hot so they won't burn up the tops of my pistons. I was also told to stay away from the split-fires. Truck ran awesome for about a week or so. then it started skipping at idle, then started losing power (slugish)and running rough. Thanks for any help!
Formon (Scott)
Old May 22, 2002 | 03:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
Running Rough
Hotter plugs? Have you pulled any and looked at them?
You should probably look thru the [link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=electrical&conf=misc|Ele ctrical Systems/Wiring] Forum for an explanation of sparkplug heat ranges. The heat range has to do with how fast the plug conducts combustion heat away from the tip of the plug back into the head and water jacket. The heat range does not have any effect on the top of your piston. You may have some melted electrodes on some plugs now
If your old plugs were not fouled with heavy oil deposits go back to that heat range. Kick "someones" but LOL
I only use a hotter plug on an individual cylinder that needs it. Usually by the time an engine needs hotter plugs all the way around it is rebuild time.
Old May 22, 2002 | 10:29 PM
lakeaustingal's Avatar
lakeaustingal
Running Rough
banks0531
37
Sep 3, 2014 08:45 PM
F250army45d
1997 - 2003 F150
Jan 30, 2011 01:20 PM
stngh8r
30
Jan 10, 2009 07:54 AM
calazo
Jan 7, 2009 10:40 PM
cigarxtc
Oct 12, 2001 01:03 PM
