vac ports
Old Mar 21, 2002 | 09:33 AM
78bronco's Avatar
78bronco
vac ports
i have a 1984 f-250 with 351W, where does the right most port on the intake manifold go to?
also where does the little port on the underside of the carb go to?
Old May 20, 2002 | 09:33 PM
shadetree_f150's Avatar
shadetree_f150
vac ports
check your vacuum diagram under the hood, but I believe the top goes to your carbon can and the bottom tees in to it.
(this is how it is on my 89 F150)
Old Jun 20, 2002 | 03:13 PM
xuare's Avatar
xuare
vac ports
*my truck doesn't run very well, take what I say with a big grain of salt*
The Haynes manual I bought for my 83 F250 has the hookup under the float bowl and next to the port side carburetor barrel as going to EGR/vac advance, though that seems kinda screwy since that port will pull vacuum at idle (which is bad for timing, since the EGR should also be closed at idle).
I'm still trying to find out about the other one myself. If my truck had a carbon can, it was ripped out by previous owners awhile ago.
LA
Old Jun 21, 2002 | 12:10 AM
GammaDriver's Avatar
GammaDriver
vac ports
LARIAT 85
20
Jul 29, 2017 07:06 AM
shotgun2
Nov 19, 2016 10:32 PM
dtkkc
Sep 23, 2016 04:49 PM
Rick_Fury
Nov 4, 2011 06:34 PM
Dopa911
Apr 26, 2004 03:03 PM
