Seatbelt Chime Code
Old Aug 29, 2009 | 06:30 AM
Bucksloopy's Avatar
Bucksloopy
Seatbelt Chime Code
I own a 2004 4x4 F150 Lariat - I was told that there is a code to turn the seatbelt chime on/off, does anyone know this code? I farm part time, and it is very annoying for the little trips.
Old Aug 29, 2009 | 09:19 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
There are directions to disable this in your owners manual. I had to do each seat individually on my 2005.
Try a Search on "disable seat belt chime", I found 5 pages of posts about this.
Old Aug 29, 2009 | 09:49 AM
abcstyers's Avatar
abcstyers
Put the seat belt in the receptical before you get in the truck...
Old Aug 29, 2009 | 11:43 AM
shorebird's Avatar
shorebird
Deactivating/activating the BeltMinder feature
The driver and front passenger BeltMinder are
deactivated/activated independently. When deactivating/activating
one seating position, do not buckle the other position as this will
terminate the process.
Read steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
The driver and front passenger BeltMinder features can be
deactivated/activated by performing the following procedure:
Before following the procedure, make sure that:
• The parking brake is set
• The gearshift is in P (Park) (automatic transmission)
• The ignition switch is in the OFF position
• The driver and front passenger safety belts are unbuckled
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
• Step 3 must be completed within 50 seconds after the safety belt
3. For the seating position being disabled, buckle then unbuckle the
safety belt 9 times, ending in the unbuckled state. (Step 3 must be
completed within 50 seconds after the safety belt warning light turns
off.)
• After step 3, the restraint system warning light (airbag light) will be
turned on for three seconds.
4. Within 10 seconds of the light turning on, buckle then unbuckle the
safety belt.
• This will disable the BeltMinder feature for that seating position if it is
currently enabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds.
• This will enable the BeltMinder feature for that seating position if it is
currently disabled. As confirmation, the restraint system warning light
will flash 4 times per second for 3 seconds, followed by 3 seconds with
the light off, then followed by the restraint system warning light
flashing 4 times per second for 3 seconds again.
Old Sep 3, 2009 | 09:24 AM
Bucksloopy's Avatar
Bucksloopy
Thanks Shorebird. Worked like a charm. My Dad has a 2006 F150 and he begged me to do it for him, He loves it also.
puckett_jw
Aug 30, 2024 11:55 AM
Recce43a
Mar 27, 2017 04:36 PM
Drwoods72
1997 - 2003 F150
Feb 14, 2017 05:25 PM
sgeorge
Jun 27, 2016 10:52 PM
BROWN DOG KTM
Jun 17, 2016 12:28 PM
