Vacuum Hoses
Old Aug 28, 2009 | 09:41 PM
cowmilker08's Avatar
cowmilker08
Vacuum Hoses
What's the story with vacuum hoses on these trucks? Do they affect shifting only or engine preformance also? What are the signs of a leak?
Old Aug 28, 2009 | 10:26 PM
madpogue's Avatar
madpogue
Vacuum leak can't affect performance, because it's not _engine_ vacuum. It's "ginned up" vacuum from the pump. Idunno the automatics, but I doubt that anything about them is vacuum controlled; that's a '70s thing. Only thing the vacuum pump connects to (AFAIK) is the HVAC control and the power brake boost. A leak will usually sound like a hissing noise.
Update - the C6 tranny has a "vacuum regulator valve" tied to the distro block.
Old Aug 29, 2009 | 11:26 AM
cowmilker08
So then the vacuum lines have nothing to do with how smooth the transmission shifts? I ask because a friend of mine has a V10 with the 4R100 which is essentially the same as an E4OD, and when he replaced all the vacuum lines the transmission started shifting like brand new again.
Old Aug 29, 2009 | 11:41 AM
arkredneck's Avatar
arkredneck
there is one vacum line that goes from the intake manifold to the map sensor that reads boost if you take that one off the truck runs like crap
Old Aug 29, 2009 | 07:18 PM
madpogue's Avatar
madpogue
His engine produces vacuum. I have no idea how the V10 with the 4R100 uses vacuum to control the tranny, but it's not gonna be the same as any of the autos with our PSDs. The 1995 EVTM shows no vacuum connection from the vacuum distributor block to the E40D.
Old Aug 30, 2009 | 02:07 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Nope our trannys have no vaccum to them fromt he distribution block. Been there looked at it lol nothing. Just HVAC and Brake Booster.
1972-34ton
Nov 6, 2014 07:38 PM
400inatruck
Sep 2, 2012 09:05 PM
Hvydudy
Feb 15, 2006 04:27 PM
hu5ker555
Jan 25, 2005 09:12 AM
jasond5150
Sep 13, 2004 12:24 AM
