Weird starting problem
Old Aug 28, 2009 | 05:33 PM
8525ford's Avatar
8525ford
Question Weird starting problem
my 85 f150 turns over real slow. I know what your all thinking and its been replaced.
replaced
1. battery with autocraft 875 ca 675 cca
2. starter solenoid/relay. ac delco cleaned fender and has good ground.
3. replaced Negative batt cable
4. replaced Positive batt cable.
5. replaced cable going from relay to starter.
6. replaced starter.
7. all connections are clean and tight.
What the hell can it be. when i crank the engine the volts drop down to 10.5. haynes says anything below 8 is bad.
disconnected wire going to starter and tested to see how much voltage is going from the batt to the relay. 12.6. no high resistance. Everything is brand new.
theres nothing wrong with the engine. nothing internal. turns over smooth with a socket on the crank????? any help please.
Old Aug 28, 2009 | 06:21 PM
ctubutis's Avatar
ctubutis
Have you checked/adjusted your ignition timing recently?
Factola72
24
Apr 7, 2014 06:23 PM
seaweaver
Oct 13, 2012 10:16 AM
vasten
Apr 16, 2011 05:24 PM
mgibsonaz
1997 - 2003 F150
Nov 11, 2009 06:57 PM
patmorrison
13
Feb 27, 2004 03:20 PM
