Sponsored by: Real Truck
ICP sensor 2003 f250
Old Aug 28, 2009 | 05:21 PM
deputybmccarver's Avatar
deputybmccarver
I have a 2003 F250 powerstroke with a 6.0 I have a engine light with a code of p2285. Bad connection, short circuit or faulty ICP sensor. The truck runs like a top should i replace it or drive it?
Old Aug 28, 2009 | 05:35 PM
Layson's Avatar
Layson
You might want to try to post in the 6.0 diesel area... you would get more hits... Good luck!
Old Aug 28, 2009 | 07:36 PM
david0505's Avatar
david0505
Icp
Just replaced mine in an '03,weak spot in these is the seal,they begin oozing oil where the electrical conn. hooks up and the oil provides a short or ground, feel with Your finger see if it's wet with oil,no fix, must replace. If using the same connector on new sensor,make sure connector is cleaned of old oil...Found My OEM part on E-bay 3c3z 9f838 ea Luck,Dave
Old Aug 28, 2009 | 07:58 PM
deputybmccarver
Thanks Dave ill go check it now! again thanks Bryan
patino1
Mar 1, 2025 07:41 PM
keiseldiesel
37
Mar 10, 2019 08:16 PM
54slewis54
Jan 15, 2015 07:43 PM
Milwaukee1979F150
20
Jul 8, 2013 11:12 PM
gamaliel
Jan 7, 2013 08:33 AM
