elec choke wire
Old Jul 16, 2002 | 09:43 PM
51truck's Avatar
51truck
elec choke wire
Iam installing new carb with elec choke. where do I wire a hot wire for the choke. A freind said to tap into the stator wire from alt. is this ok? Thanks
Old Jul 16, 2002 | 10:08 PM
Franklin2's Avatar
Franklin2
elec choke wire
Some of the posters have said on here before that the stator output on the alt is not a full 12 volts, which is fine for the factory choke which is designed for it, but it has been said the aftermarket carbs need a full 12 volts, which would have to be brought from the fuse box acc or ign section.
Old Jul 17, 2002 | 03:17 PM
51truck's Avatar
51truck
elec choke wire
Could I wrun a wire from the I terminal on the starter silanoid
Old Jul 17, 2002 | 08:54 PM
topo4u2's Avatar
topo4u2
elec choke wire
I just finished hooking up an electric choke cause I was sick and tired of that stupid hot air choke. It works just great and it is connected to the "S" terminal of the alternator.
Old Jul 19, 2002 | 06:04 PM
Franklin2's Avatar
Franklin2
elec choke wire
Solenoid connection won't work since it receives 12 volts only on start-up. You need 12 volts on the choke as long as the engine is running. topo4u2 said his worked on the stator connection, so if possible I would use it. This is the best way, since it only puts out voltage if the motor is running.
Old Jul 20, 2002 | 04:30 PM
skipper's Avatar
skipper
elec choke wire
bigcrunch
Jan 26, 2017 01:24 AM
DaytonaTunnel
Apr 11, 2012 06:02 PM
erawtik
Bronco II
Jun 30, 2007 05:43 AM
Benztechnc
Feb 27, 2006 10:17 PM
wiznewski
Sep 17, 2003 05:00 AM
