Good luck with that. There is a reason why guys drop Cummins into their Fords, much cheaper to get high HP and much more reliable at those numbers.
But.......You may be in luck. Swamps seems to be coming out with some things lately that may make some big HP numbers, but who knows.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Yes, nothing replaces displacement, nothing. Now forced induction engines artificially increase the displacement and therefore the fuel that can be burned. That means you need to put more air (oxygen) in there and more fuel to make more power. The 7.3 falls on it's face here where the 5.9 just takes a pounding and asks for more. That is as simple as I can make it. The 7.3 was not built to make 400hp, like I do, let alone 800-1000 like many 5.9s do. Yeah, there are many 500hp plus 7.3s out there. They usually lead a short life unless carefully tuned and well cared for.
Thanks Greg. This is a frustrating subject. Many folks more apt than me have been working on this problem for years. This is not a new topic and has been well discussed here and elsewhere.
Yes you are right on with that!
I think thats why there are so many more Dodges at diesel events than any other diesel truck. Doesn't cost near what it does with a Ford to make good HP.
Hey, we don't suck. I am pretty happy with my truck. I long ago accepted I won't ever have the fastest anything. There will always be someone spending more to be faster. My truck is still pretty darned fast. Good enough for me for now.
Mike you are right we dont suck. But damn with a dodge you can get a fuel kit $150.00 a Big set of injectors $350.00 and a chip that you can keep down loading tunes for free for $500.00 and be in the 14 seconds club no problem. But as you say I am happy with my truck for now
I have had a 5.9 great engine but when i put the power up on it (around 300 hp and 750 tq) the EGTs would get so high so fast when towing i had to tow slower and it felt like i had more weight (same load) behind me then with my 7.3 with a edge tuner with 160 tq option. I can nail it with my 7.3 with 6500 pounds towing and not even get about 1000 degrees. Its a great towing setup but would never be in the same area as my dodge was with getting up and going. That truck was quick could stay dead even with my brothers Harley. To bad the cummins is in a dodge i went threw 4 trans and 3 times was with and ATS trans, And that is the most despicable company i have ever delt with. When something broke it magically wasn't covered under warranty.
There are several Ford 5.0 engines making near 1000 HP with a blower. This is a 7 liter engine. Again I'm not sure why the big motor is not making the big HP...
Look more into the injection system and you may understand more about why the differences.
You cant keep comparing diesel to top fuel dragsters.
Gas motors and Diesel motors are ALOT different. As a few people already said, the 7.3 just wasnt built strong enough to hold high HP numbers. The rotating assembly just cant handle it. Then theres the problem with the HEUI fuel system and then the HPOP. Because of the injectors firing off of oil pressure we have to make the power lower in the power band since you just cant get enough volume to fill the pumps and maintain the oil pressure you need at higher RPMs.
Arnt the 5.9s injectors fired off fuel pressure? I cant remember at the moment?
Agreed with Chris comparing gas motors to diesels is apples and oranges. Apples and oranges are both round, gas motors and diesel motors are both use oil. Thats about where the similarities end. The only other thing to point out is to look at the stock torque #'s on a straight 6 gas motor compared to the torque #'s on a similar sized v8 motor.
Bottom line. the 5.9 has been around for eons. The longer anything is in existence's the more/easier ways people find to improve it.
dodge may have the best motor but the rest of there trucks suck. were spending money on our motors and dodge guys spend all there money on keeping the truck from falling apart!
Nope...not wanting to start trouble at all. But to me seems like we're going against the grain. Show me a 9 sec 6 cyl car...won't find any. So why is it that a V8 config makes less sense in a diesel? There are plenty of 2000+ HP cars out there and none of those are inline 6s. I'm just trying to figure out why the inline 6 works better for high HP diesels...or does it????
I am gonna start trouble with this one even though I am not meaning to, and not sure if anyone else caught this one.....three words meaning 9 second v-6 car, Buick Grand National
No worries. Same idea with increasing displacement with forced induction. That engine was built for that. It was well made. They worked on that for a few years to be the fastest American production car in the 1/4 mile and did so in either 87 or 88 beating the Corvette. Then after proving that point, production ended. BTW, The GN was giving the 5.0s fits back then on the track. Yes a V6.
Edit: I forgot to mention, I almost bought one of those brand new right off the dealer lot back in 88. I was drooling over it.
