2002 explorer bearing and hub replace
Old Aug 27, 2009 | 03:54 PM
Mustang6t7's Avatar
Mustang6t7
has anyone changed a bearing and hub assy. on a 2002 explorer?
thanks
Old Aug 27, 2009 | 05:23 PM
steve(ill)'s Avatar
steve(ill)
yes, i bought on e-bay for about $90. installed at about 80k miles. Remove tire/wheel. Remove brake caliper and disc. Loosen the big axle nut, maybe 28-30mm deepwell? Push the axlle inward 1/2 inch to get the CV joint away from the back of the hib. Use a hax 15 mm box wrench to remove the three bolts on the back of the knuckel that hold the hub on. THey are TIGHT and may have loctite on them. Get a GOOD wrench that can be smacked with a 2 pound hammer. Some have to heat the bolt threads at the hub to melt the thread lock. After the three bolts are out, remove the ABS wire connector, and pull the hub out over the axle spline. Splines may be cruddy or some rust, may have to use a small press or puller to push out the axle.
Old Aug 27, 2009 | 05:26 PM
Mustang6t7's Avatar
Mustang6t7
Thanks for the help, will come in handy
Old Aug 28, 2009 | 11:26 PM
fordmerc's Avatar
fordmerc
Are you talking about the front or rear of the vehicle. They are very different in how you have to replace them.
Old Aug 29, 2009 | 06:46 AM
Mustang6t7's Avatar
Mustang6t7
front bearing
Old Aug 29, 2009 | 08:38 AM
steve(ill)'s Avatar
steve(ill)
The description i gave is for the front. If you do the rear it is more difficult. On the rear you have to remove the knuckel from the truck and press the bearing out in a hydraulic press, then push the new one in. THe hub and bearing units look similar on the rear.
Old Aug 29, 2009 | 01:02 PM
Mustang6t7's Avatar
Mustang6t7
thank you much for all the info
Old Sep 1, 2009 | 01:55 PM
1Aauto's Avatar
1Aauto
Former Vendor
HI,
Just saw your post. Not sure if you needed a set of hubs.We do have them in stock.Here's a link to them if you would like to check on pricing.
Explorer Hub Assemblies
b07bruce
Nov 1, 2013 07:15 AM
lovemy150's
Oct 1, 2010 06:15 PM
broncobasher
15
Feb 18, 2007 11:50 AM
RA81222
Mar 20, 2006 02:26 AM
pappoo
Mar 9, 2005 08:12 PM
