Manifold heat riser
Old Aug 25, 2009 | 11:58 PM
bobaloo11's Avatar
bobaloo11
Manifold heat riser
I have a 1973 300ci.
Simple question... I hope.
What position is the outer spring/shaft supposed to be in (looking at the rear of the engine) when the engine is warmed up. I don't want to drive around in the heat with the manifold heater on. Not real great on gas that way!
Thanks in advance
Old Aug 26, 2009 | 10:10 AM
AbandonedBronco's Avatar
AbandonedBronco
IIRC, it rotates counter clockwise to open. So, it'll be "up" when warm, and "down" when closed.
Does it freely rotate?
Old Aug 26, 2009 | 07:15 PM
bobaloo11's Avatar
bobaloo11
Yes it freely rotates. I hooked it with the counterweight in the "up" position, (full clockwise) using a small tight spring. So I can assume that the valve is in the closed (NOT heating the intake manifold) position, right?
Thanks.
Old Aug 28, 2009 | 01:24 PM
AbandonedBronco
If the riser is freely rotating, why do you want to lock it in place? It closes automatically when the engine warms up, cutting off manifold heat to the carburetor.
The position it's in when the engine is cold and at rest is going to be fully open, so if you rotated it and locked it in place, then yeah, you have it closed.
Old Aug 28, 2009 | 03:30 PM
bobaloo11's Avatar
bobaloo11
The valve rotates freely, but the bi-metallic spring is broken, which is common, that keeps it in the open position. Since it's only real purpose is to prevent carburetor icing and that only happens when conditions are right. The van is an icecream truck-to-be so I don't think I'll be worring much about that.
Thank you for your information... it will help keep ice cream prices down!
Old Aug 29, 2009 | 07:11 AM
BigBlue88's Avatar
BigBlue88
Not just icing, but driveability in general, especially in cold weather. That hot spot on the bottom of the intake keeps fuel atomized when not in a high-vacuum situation. Loose the heat, and you'll get mixture problems and terrible running under any load, especially at low speeds/throttle, when you have low airflow speeds in the intake manifold. Fuel just drops out of suspension and puddles in the intake.
Old Aug 29, 2009 | 09:20 AM
AbandonedBronco
I was about to mention that, but you beat me to it.
If you're interested, Rockauto.com has an entire heat riser replacement kit for $70 (spring, plate, etc.). I wonder if it's possible to just source the spring from Ford?
Old Aug 30, 2009 | 08:45 PM
vincenthp's Avatar
vincenthp
This should help, if you haven't got it figured out already.<a href="http://s809.photobucket.com/albums/zz12/futlocker/?action=view&current=IMG_3788.jpg" target="_blank"><img src="http://i809.photobucket.com/albums/zz12/futlocker/IMG_3788.jpg" border="0" alt="Hot air valve picture"></a>
Old Aug 30, 2009 | 11:14 PM
bobaloo11's Avatar
bobaloo11
Exclamation
I appreciate the picture, but now I'm more confused. The picture shows that when the plate is in the vertical position, the valve is open and the heat is off. When in the horizontal position the valve is closed and the heat is on.
I'm confused by this because when the valve is in the vertical position it exposes the bottom of the intake to exhaust heat. (when cold). But the picture is labeled valve open HEAT OFF. When the valve is in the horizontal position the valve is closed and the exhaust heat is then diverted away from the bottom of the intake. This should be heat off.
Am I missing something here? Shouldn't it be vice versa?
Old Aug 30, 2009 | 11:27 PM
vincenthp's Avatar
vincenthp
My truck runs all the time in the vertical position.
When I run it in the horizontal position it runs good for only a short period of time.
Until it warms up.
Vincent
Old Aug 31, 2009 | 07:27 AM
vincenthp's Avatar
vincenthp
Here is another picture
<a href="http://s809.photobucket.com/albums/zz12/futlocker/?action=view&current=6e9b_1.jpg" target="_blank"><img src="http://i809.photobucket.com/albums/zz12/futlocker/6e9b_1.jpg" border="0" alt="Photobucket"></a>
Old Aug 31, 2009 | 12:19 PM
bobaloo11's Avatar
bobaloo11
OK. That is the vertical position, the valve is open allowing the hot exhaust gasses to contact the bottom of the intake, just under the carb. Once the engine warms up, that closes into the horizontal position and diverts the gasses away from the intake manifold, allowing for a cooler air/fuel mixture and better economy. Or is there something I'm missing? Is the plate covering a port in the exhaust manifold or something?
The reason I'm confused goes back to when I had a 1950 Dodge Pick-up. It had a similar setup. These were "show vehicles" and the majority of the owners I chattrd with would take the manifolds apart and weld the valve in the hoizontal position to keep it from rattling or sticking open causing very poor gas mileage.
Old Aug 31, 2009 | 01:38 PM
vincenthp's Avatar
vincenthp
When in the horizontal the valve directs the full exhaust to the base of the intake.
As it heats up it turns to vertical, opening the way to the exhaust.
The intake still receives heat just not as much, for now the way to the exhaust is open.
Because of the constant heat supply, I was still having trouble with mine boiling the fuel in the carb after shut down.
I made a heat shield to absorb the heat instead of the carb no more problem with the carb getting cooked.
Vincent
<a href="http://s809.photobucket.com/albums/zz12/futlocker/?action=view&current=IMG_3782.jpg" target="_blank"><img src="http://i809.photobucket.com/albums/zz12/futlocker/IMG_3782.jpg" border="0" alt="heat shield"></a>
<a href="http://s809.photobucket.com/albums/zz12/futlocker/?action=view&current=IMG_3780.jpg" target="_blank"><img src="http://i809.photobucket.com/albums/zz12/futlocker/IMG_3780.jpg" border="0" alt="Photobucket"></a>
Old Aug 31, 2009 | 10:35 PM
bobaloo11's Avatar
bobaloo11
I got it now. Thanks!
I like what your doing with your 4.9. The shield is a great idea plus it looks well done too!
I'm thinking of getting an aftermarket air cleaner for mine too. I have an old oil bath air cleaner. Not really necessary for what I'm doing and cleaning it can be a mess too.
Bob
Old Sep 1, 2009 | 11:10 PM
vincenthp's Avatar
vincenthp
Thank you for the compliments.
I was glad to help out.
I think the air cleaner really helps it breath better.
Vincent
johaner78
15
Oct 12, 2020 11:01 PM
Old Yblockman
22
Nov 10, 2019 03:32 AM
Vegas123
22
Aug 6, 2019 12:18 PM
1986F150six
15
Sep 6, 2015 08:13 PM
dan&levi
Apr 22, 2010 08:00 AM
