Ford 226 Oil Exhaust leak at manifold, heat riser?
Old 10-31-2015, 09:21 AM
Vegas123
Vegas123 is offline
Vegas123 is starting off with a positive reputation.
Hi Guys,
Well I finally corrected the oil pressure and small coolant leak that I had with the motor.
I ran the motor yesterday and everything looked fine except that I noticed an exhaust leak where the heat riser is located on the exhaust manifold. Sounds and feels like its located directly where the heat riser shaft comes out of the exhaust manifold.
I really do not want to remove the exhaust manifold to fix it, ANY ideas on how to best fix the problem without removing the manifold?
Thanks
Old 10-31-2015, 10:25 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
Best way? Remove the manifold.
Old 10-31-2015, 01:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
Is it leaking around the shaft? or at the center cylinders' head connection?
Old 10-31-2015, 01:35 PM
Vegas123
Vegas123 is offline
Its Leaking around the shaft.
The heat riser does not have the coil spring attached.
It was removed so I can clear feel and see the leak around the shaft.
High temp gasket gel???
Old 10-31-2015, 06:10 PM
fordf348's Avatar
fordf348
fordf348 is online now
fordf348 has a good reputation on FTE.fordf348 has a good reputation on FTE.
I am watching this thread because mine leaks there too, it doesn't seem to hurt anything. Is there any reason to be concerned with it?
Ed
near Philadelphia
Old 10-31-2015, 06:19 PM
fordf348's Avatar
fordf348
I misread that.....mine leaks air around the shaft not oil
Old 10-31-2015, 06:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't know how oil could get there?
Old 10-31-2015, 06:27 PM
fordf348's Avatar
fordf348
Now I am confused, the title says oil exhaust leak,,,,,,,is it an oil leak or exhaust air leak?
Old 10-31-2015, 09:30 PM
Vegas123
Vegas123 is offline
Sorry guys I ment to say exhaust leak.
It's an exhaust leak, NOT an oil leak.
Old 11-01-2015, 06:18 PM
3twinridges's Avatar
3twinridges
3twinridges is online now
3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all
there are a set of bushings, one on each side of the manifold that the shaft pivots on, I just replaced mine. Yours are probably rusted a little creating clearance.
Old 11-03-2015, 12:40 AM
CBeav's Avatar
CBeav
CBeav is offline
CBeav is a splendid one to beholdCBeav is a splendid one to beholdCBeav is a splendid one to beholdCBeav is a splendid one to beholdCBeav is a splendid one to beholdCBeav is a splendid one to beholdCBeav is a splendid one to behold
If the valve has been removed you can tap the holes and install screws, bolts or brass pipe plugs.
Old 11-03-2015, 07:56 AM
Vegas123
Vegas123 is offline
Thanks for ideas! Any tips on easiest way to cut out that heat riser?
Old 11-03-2015, 04:47 PM
3twinridges
Those heat riser parts are impossible to find as FYI. I would try to save what you have. You can grind down the welds on the flapper and the shaft will slide out. Check to see if it's the shaft or bushings. Maybe have a machine shop make you some new bushings? I do think the engine runs better cold or warm with a working heat riser but I am a purest and want everything original which I know is rare.
Old 11-03-2015, 05:57 PM
Brian~50F3's Avatar
Brian~50F3
Brian~50F3 is offline
Brian~50F3 is starting off with a positive reputation.
Twinridges is right, parts are impossible to find!
Here's what I did/am in the process of. I cut the valve out using a hack saw blade very carefully on each side of the valve.
I cleaned up the valve on a wire wheel, and then used a dremel to very carefully grind/cut the welds holding the valve to the shaft, then drove it out with a punch.
I purchased a heat riser repair kit for a 41-53 ****** jeep, basically this one, just off ebay.
Manifolds & Parts - Exhaust Manifold Heat Riser Repair Kit Fits 41-53 Jeep & ****** with 4-134 L engine
The shaft is the correct diameter, but O.D. of the bushings is too big. The shaft is also about 3/4 in too long, no prob just cut to correct lenght.
So I mic'd the bushings and found the appx size on amazon, here's the comparison:
counterweight on the far left is for the jeep, first bushing is the original, second is the one off amazon, and third is the too big bushing from the jeep kit.
The spring that came in the jeep kit wasn't correct for the ford, so I did some searching and it seems the 55 chevy 6 used the same spring for the heat riser. Ordered off epay and here's the comparision:
Left spring original, upper right spring for the jeep, and bottom right the chevy spring.
This should be everything but the counterweight, WHICH I NEED if anyone has one please PM me! I have not re-installed everything yet, have a broken stud on the manifold I've been draggin my feet on geting out; but it should all go together fine. Once the new bushings are pressed into the manifold they may need a slight reaming but not too much or you'll have a leak again
Also I think you can find just the shaft from the jeep kit on ebay as there's no need for the whole kit. Hope that helps!
Old 11-03-2015, 06:15 PM
abe's Avatar
abe
abe is offline
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Brian, excellent tutorial on repairing the heat riser.
Quick Reply: Ford 226 Oil Exhaust leak at manifold, heat riser?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
