im cofused...
Old Aug 25, 2009 | 01:02 PM
truckdriver_mn1984's Avatar
truckdriver_mn1984
im cofused...
again. I was told by napa I have a 351. not a 302... Everything i have checked, and others i have talked to and a family member that bought the truck new, says its a 302. But 2 napa guys say 351....
How can i tell for sure? Im working on getting the door sticker readable. I looked on the motor i cant find any markings...
Any tell tale differences i can go by?
Old Aug 25, 2009 | 01:05 PM
Conanski's Avatar
Conanski
It's easy.. measure the width of the lower intake manifold bolt to bolt? Roughly 9" = 302, 11" = 351.
Old Aug 25, 2009 | 01:06 PM
Sportruk's Avatar
Sportruk
Measure the width of the intake manifold between the rocker covers. 302 is 9" and the 351 is 11".
Edit: Damn, you're quick on the reply button.
Old Aug 25, 2009 | 01:12 PM
Conanski's Avatar
Conanski
Actually I just too a quick measurment and it's more like 8" for the 5.0 and 9.5" for the 5.8. You can also ID the motor by the height of the distributor base on the block, roughly level with the intake manifold is a 302, about an inch below and it's a 351.
Old Aug 25, 2009 | 01:28 PM
Sportruk's Avatar
Sportruk
You must have one of those rubber tape measures. I measured the 351 here under my workbench and it measures right on 11". The bolt centers are 9 1/4".
Old Aug 25, 2009 | 01:30 PM
Conanski's Avatar
Conanski
Yeah.. bolt centers is what I was talking about.. outside dimensions would be more of course.
Old Aug 25, 2009 | 01:35 PM
Sportruk's Avatar
Sportruk
Doh, missed where you said bolt to bolt in your first post.
Old Aug 25, 2009 | 02:20 PM
truckdriver_mn1984
oh ok thanks guys ill have to try it. is there a site for decoding vin numbers? id like to find out for sure on my others also
Old Aug 25, 2009 | 02:34 PM
Sportruk's Avatar
Sportruk
The VIN at the base of the windsheild has the engine size.
https://www.ford-trucks.com/vin-decoder/index.php
For the door sticker decoder.
https://www.ford-trucks.com/article/...r_Decoder.html
Old Aug 25, 2009 | 04:02 PM
Virto's Avatar
Virto
Vins and door tags only work if the engine has never been changed.
What year truck is this, 1984? So not fuel-injected.
I was going to say, the injected truck intakes have 5.0 EFI or 5.8 EFI right on the top.
Old Aug 25, 2009 | 05:39 PM
truckdriver_mn1984
Its a 87, its EFI. But theres nothing on the intake. not even a ford emblem
Old Aug 25, 2009 | 06:17 PM
Virto's Avatar
Virto
That's really weird, although in some ways the 87 was an odd pony.
I haven't owned one that far back, but I did own several in the same body style and they all had the embossed upper intake. I wonder if that was normal for the '87 or if it's not the factory intake.
Old Aug 25, 2009 | 06:22 PM
Sportruk's Avatar
Sportruk
Oh, in that case, it's a 302. The 351 didn't get EFI until '88.
Old Aug 25, 2009 | 06:55 PM
Old93junk's Avatar
Old93junk
Good call, 87 351 will have a 4180 Holley/ Motorcraft 4bbl carb and 5.8 4V H.O. decal on the aircleaner.
Old Aug 26, 2009 | 03:20 AM
TexasGuy001's Avatar
TexasGuy001
Isn't there an emissions sticker under the hood that says?
I believe they are correct that the 351 didn't get EFI until 88.
