66 Ford F100 automatic with 353 engine
Old Aug 25, 2009 | 12:02 PM
ford66's Avatar
ford66
The 66 Ford F100 I just bought has a automatic. In the mornings the automatic sometimes when setting still, will go out of gear and then bang back into gear, then does better when it warms up. Any idea what the problem could be? It has a 352 engine. Does it have filter? I haven't check the tran to see if it needed fluid.
Thanks
Ford66
Old Aug 25, 2009 | 12:10 PM
bertha66's Avatar
bertha66
If it were mine, I would start with a base line, change the filter and fluid. That way you know that everything is good. Then if it still gives you trouble, check that the modulator is got good vacumn or if needed you can have the bands ajusted.
Old Aug 29, 2009 | 11:49 AM
customcab66's Avatar
customcab66
thats what i did to mine ran good till the tranny let go but it had other problems when i bought it
ford66
Mar 6, 2012 03:41 PM
ford66
Oct 30, 2009 05:31 PM
ford66
Aug 27, 2009 08:06 PM
ford66
Aug 17, 2009 08:09 PM
ford66
Aug 9, 2009 12:55 PM
