is there any one who makes a replacement radiator support for the 94 - 97 PSD ?
I have gotten 3 for my truck from LMC and each time they said "this is the right on for the F250 with the diesel engine, all were 23 1/2 inches tall mine is 29, ordered one from Certifit today they said this is the one for the 94 to 97 F250 with the diesel engine! My father was in Phoenix today so I had him go by to pick it up, when he measured it it was 23 1/2 inches tall? but they swear it is for the psd! I have 2 '97 psd's sitting in my shop right now and both are 29 inches tall. where do I find supports? or am I suposed to get a smaller radiator?
As far as I know, the only way is to get one from a junk yard. Ford no longer makes them & the ones from LMC are for the IDI engines. I found mine thru car-part.com.
I repaired this one, I used 2" 1/8" thck angle on the backs side, mitered to fit around everything and welded the entire perimiter. than on the front I had a piece of 16 guage bent into an angle and fit it around everything, welded the entire perimiter and also about 15 roset welds on the top and front surface. we will see hao this holds up, this truck is #2 (this customer has about 50 trucks) on the list of trucks that get treated rough! so if it holds up the rest of them will.
