Mounting new Bilstein shocks
Old Aug 25, 2009 | 04:36 PM
  #31
zx250's Avatar
zx250
Of the next Riffraff East
So, which way did you mount them?
Old Aug 25, 2009 | 04:45 PM
  #32
FSJ-EARL's Avatar
FSJ-EARL
Both of them, boots down fronts and rears, lefts and rights ; )
Old Aug 25, 2009 | 04:55 PM
  #33
zx250's Avatar
zx250
If labels are right and bushing all fit, then it must be right.
Old Aug 25, 2009 | 05:03 PM
  #34
big poppa's Avatar
big poppa
Originally Posted by FSJ-EARL
Middletown, PA 17057 - as in Harrisburg / Hershey area. My part numbers are correct, the bushing / sleeves are in the proper location, the labels are readable in the current posistions. But if you want to meet up sometime we can! Let me know!
EARL!
Gotchya, now I remember. The next Pa. GTG, I'll shoot you a PM
Good deal Earl, let us know how everything turns out, ride, handling, ect.
  #35
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Boots down. It's been many months since I got my 5100s but in each box was a small pamphlet. Reading through that confirmed that the Bilsteins were to be mounted boot down. I thought it was weird, but that's how they are designed to work, so so be it.
Old Sep 12, 2009 | 05:16 PM
  #36
afisherdba's Avatar
afisherdba
This board rocks. Mine came with no instructions. The rear installed fine - boot up, but I could not get the front installed. It never would have occurred to me to mount them boot down. I figured I'd just put the Bilsteins on the same way the Ranchos came off. Boy was I getting pissed. In fact, put the old ones back on. Sometimes, it's just the simply things that get you.
Thanks guys!!
Old Sep 12, 2009 | 09:02 PM
  #37
Tenn01PSD350's Avatar
Tenn01PSD350
Well it used to be exactly as Barry posted for that series of Billies. IDK if they have changed the design on the rear unit or not because it used to look like what Barry posted on the left. Also what the 6.0 poster posted up.
Are you sure you got the right part #? Not starting anything, just curious if there has been a change. I still have to buy my rear shocks.
Old Jul 13, 2010 | 10:35 AM
  #38
OnTheTrail's Avatar
OnTheTrail
I had the same question so I emailed the place that I bought mine. Here's his response below. I mounted mine boot down as the other way, the boot could fill and hold water down at the bottom zip-tied seal.
"...With the internal design of the Bilstein monotube gas shocks, it does not matter whether the shocks are mounted with the shock rod side up or down. There are some minor advantages in longevity and overall suspension effectiveness with the shock rod pointed down, and there are many instances where Bilstein has changed the orientation to take advantage of these minor improvements where there are no clearance problems. If there is an option, we recommend mounting the shock with the shock rod and boot pointing down, but in the grand scheme of things, there is no noticeable difference.
Old Jul 13, 2010 | 02:18 PM
  #39
damicofuel's Avatar
damicofuel
A little off thread, my fronts seem to bottom out if I hit the dip at the end of the drive a little too fast. Anyone have this problem?
aparrothead
Mar 16, 2014 09:17 PM
SeminoleSlim
25
Jul 15, 2008 10:32 PM
fordkev
3.8 & 4.2L V6
Feb 9, 2008 06:33 PM
cmnegethon
Aug 28, 2007 01:51 PM
econolinedriver
1997 - 2003 F150
Feb 17, 2007 07:58 AM
