Mounting new Bilstein shocks
Old Aug 24, 2009 | 04:28 PM
big poppa's Avatar
big poppa
Originally Posted by zx250
Not sure what to tell you here's what I got from Shockwarehouse.
Wow, Barry's pic shows what I got from theshockwarehouse, the rears are on the left, boots at the top installed and the fronts are on the right, boots down installed. Don't know what else to tell you also.
Old Aug 24, 2009 | 04:38 PM
zx250's Avatar
zx250
Of the next Riffraff East
The pictures are from Shockwarehouses site and are the numbers Earl listed which are exactly what I got on my truck and they had instrustions stating boots down on the front and boots up on the rear. Labels on the shocks also indicate that as well. Not sure what the difference it and it probably don't matter.
Old Aug 24, 2009 | 06:21 PM
Tecman's Avatar
Tecman
on mine all boots down. but mine are the 5125s that are nickel plated with black boots. The labels all read normally
Old Aug 24, 2009 | 06:51 PM
jdecker88's Avatar
jdecker88
Thats how me and Cory mounted mine I do believe
Old Aug 24, 2009 | 08:18 PM
Joe_914's Avatar
Joe_914
Bilstiens are not particular to either way you mount them, inverted is perfectly acceptable for most quality shocks, I have AFCO and PRO shocks on my race car they have performed flawlessly for years.
Old Aug 24, 2009 | 09:49 PM
Headviking's Avatar
Headviking
Post here is my setup
Front
Rear
I took these pictures tonight.
Old Aug 25, 2009 | 05:37 AM
FSJ-EARL's Avatar
FSJ-EARL
Both of mine look like the ones on the right. They both have the accordian bellows on them with drain holes. Not sure what is going on. The fronts state specifically to mount boots down. Like I said in the first post i would have had to drive out the factory installed metal sleeve in the rubber bushing to actually put them on the other way around, I did try and it was darn near impossible to get it out.
Old Aug 25, 2009 | 05:53 AM
zx250's Avatar
zx250
I would just mount them with the label reading right and whatever is easiest for you.
Old Aug 25, 2009 | 06:03 AM
spdmpo's Avatar
spdmpo
The fronts are pretty self explanatory and go boot down. The rears on mine are boot down. The top busing on the shock body shouldn't have a steel bushing since it slides over a stud. Sounds like you described it how it should be.
In the end, it really doesn't matter, just mount them how they are set up from Bilstein. Don't take the bushing out and swap ends, just put it on how it goes.
Old Aug 25, 2009 | 08:23 AM
brian42's Avatar
brian42
Veteran: Navy
It looks like if you have the accordion looking soft boots they get mounted down, and if you have the firm (smooth) boot it gets mounted up. As much as everybody raves about the Bilsteins, there always seems to be a question about which way they get mounted. I'm surprised that a top-notch company like Bilstein doesn't include better instructions, but that won't stop me from getting a set soon .
I live about 5 miles from their headquarters and one of these days I'm going to have to stop by and ask them...
Old Aug 25, 2009 | 08:33 AM
big poppa's Avatar
big poppa
[quote=FSJ-EARL;7865121]Both of mine look like the ones on the right. They both have the accordian bellows on them with drain holes.[quote] I don't know but there has been stories of different shocks in boxes, mistakes, returns, ect. Call the place where you got them and question them the reason for the same shocks all around. Barry's pic tells the story, thats the shocks you should have per your part numbers, I have the same, unless i,m missing something, but I think a mistake was made with your rears.
Old Aug 25, 2009 | 03:44 PM
FSJ-EARL's Avatar
FSJ-EARL
The part numbers are correct for the application. The fronts are the proper number as are the rears. As per the Bilstein site.
Old Aug 25, 2009 | 03:50 PM
  #28
zx250's Avatar
zx250
Are the labels all the same way? If not, then they probably have change to the flexible boots and still need to be mounted boot up. EDIT: on the rear
Old Aug 25, 2009 | 03:56 PM
  #29
big poppa's Avatar
big poppa
Earl, what Middletown, Pa.?? Is that in Delaware county or in Montgomery Co.?? Maybe we could meet up and take a look as these shocks. Maybe Barry's right, maybe they did switch over to the better boots, the plastic ones are kinda cheap(IMO) subscribing again.
Old Aug 25, 2009 | 04:13 PM
  #30
FSJ-EARL's Avatar
FSJ-EARL
Middletown, PA 17057 - as in Harrisburg / Hershey area. My part numbers are correct, the bushing / sleeves are in the proper location, the labels are readable in the current posistions. But if you want to meet up sometime we can! Let me know!
EARL!
