Hello every one,
Just got back form a 6,500 mile trip with my 7.3 and everything went flawless with it. So Yesterday when I got home I started the 6.0 and it started right up and ran fine shut it off. I noticed a small puddle of oil under it witch I thought was weird. I think the truck has sat for the last Month I know not good for it but it was the way it worked out. So went out today and no start So I throw code reader on it and I got these codes. Po603, P1378 and P2614. So I cleared the codes and tried again still no start but I scanned again and the P2614 code came back. Any ideas?
Thanks,
Nick
P.S this is not my month for Diesels. Our 6.4 is still in Oregon getting the Motor replaced LOL
P603 is a keep alive memory code, if you had a chip on it then thats probably why you get that code. P2614 is your culprit. Thats a cam sensor code, I would try replacing it $30, hidden behind p/s pump driver side. Also check the wiring to make sure that a critter did not chew threw the wiring.
