Transmission lags when cold
Old Aug 23, 2009 | 03:35 PM
dzwiss's Avatar
dzwiss
When I first start out with a cold engine the transmission seems to take a long time to shift into second and third. When it does shift it shifts hard, or jerky. After a couple of cycles like this it smooths out and shifts normally. I checked the fluid and it is full. Any ideas as to what might cause this and is it a problem?
Old Aug 23, 2009 | 05:25 PM
pjwoolw's Avatar
pjwoolw
Pretty sure mine does that too if I start off cold. Always has. I don't take off cold often. Every time I suspect something odd with the tranny fresh fluid has seemed to take care of it.
Old Dec 16, 2009 | 04:37 PM
dzwiss's Avatar
dzwiss
Problem solved
I had a starting issue when the temps dropped to 2 degrees the other morning. The PSD was hard starting and blew a lot of black smoke, then stopped running. Restarted fine, but I had a check engine light. Took it in and the fix was to reprogram the computer, apparently there was a TSB on the situation. So, it now starts great and the transmission doesn't lag when starting out cold. It only took about six months to get that straightened out, but it's all good now.
Old Dec 16, 2009 | 06:08 PM
69cj's Avatar
69cj
how many miles are on it and has the tranny and ext. filter been serviced?
Old Dec 17, 2009 | 01:06 PM
dzwiss's Avatar
dzwiss
There are 53,000 miles on it and I have had the transmission serviced twice, the last time less than a month ago. It's running great now.
Old Dec 17, 2009 | 02:35 PM
rodolan's Avatar
rodolan
Mine does same thing only when it's cold otherwise perfectly normal..
Old Dec 17, 2009 | 04:50 PM
powerstroke72's Avatar
powerstroke72
Mine has done it since it was new. The transmission always shifts like that until it gets warmed up a bit. You can feather the throttle and get almost out of it completely before it will shift but after it warms up it's fine. The latest flash took care of some of it but the rest I've chalked up to being normal. It doesn't do it nearly as bad in the warmer months but it's been in the single digits overnight here lately and I've noticed it doing it a little more.
Old Dec 18, 2009 | 05:06 AM
RigET's Avatar
RigET
Mine is the same way if I dont let it warm up for a few minutes.
Old Dec 18, 2009 | 06:50 AM
Rob.D's Avatar
Rob.D
You would be suprises at how long it takes for the tranny fluid to get upto normal operating temps. Since I've installed the Spartan Phalanx I can now monitor temps. When it's cold here, it may take 20+ miles before I see normal temp, 145F if I remember correctly. The oil/coolant temps come up much quicker.
gbrewer
Jan 13, 2015 07:51 AM
LiquidSpecialties
2004 - 2008 F150
Dec 21, 2014 06:54 AM
bsitterson
1997 - 2003 F150
Dec 3, 2013 10:24 PM
colbyp
Aug 14, 2010 01:57 PM
