Aerostar Ford Aerostar
Instrument Cluster Pin/circuit function diagram
Old Aug 22, 2009 | 10:16 PM
93nighthawk's Avatar
93nighthawk
Just curious if anyone has a pic of the Instrument Cluster PIN/Circuit Function diagram for a '92-'95 Aerostar?
I am working on a project and I am hitting a stopping point without it. I have the PIN diagram for my '97, but I have a feeling that it is not telling me everything I have. I think that they might have left some info out, or they did a running change, which will make things difficult for me.
And while I am at it, does anyone have a Instrument Clutster PIN/Circuit function diagram for a 92-96 Ford F-150?
EDIT: Crud, I did a search for the F-150 printouts, and dang you Ford! Why didn't you use the same connectors, you used the same instrument clusters across the lines.
Here is the link with the pics:
https://www.ford-trucks.com/forums/8...e-diagram.html
Old Sep 5, 2009 | 11:02 AM
93nighthawk
Burump!
Does anyone have the IC pin layout for the 92-95 Aero? Or know if there are a seperate set of connectors for the the Digital dash (with tach) laying there in the dash, just waiting to be used?
Old Sep 6, 2009 | 04:22 PM
cookkd's Avatar
cookkd
I can tell you about my 91.....the plugs for the digital dash are not there. If I remember correctly, all the signals are there (after you replace your sending units with the ones for the digital) except one. That was the "fuel flow input". I had to tap that at the plug for the EEC and lead it in through the dog house.
Old Sep 6, 2009 | 10:48 PM
93nighthawk
Looking at my diagram, there is no tach signal wire to the instrument cluster.
Rogue_Wulff
'80-'86 HOWTO's
19
Jan 21, 2025 10:13 PM
rj1983
Australia Chapter
Jun 2, 2024 08:49 PM
Daves truck
26
Jan 12, 2018 11:29 PM
Tomoryears
6.4L Power Stroke Diesel
Oct 27, 2016 06:45 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
