Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Reload this Page >
How to restore "ELECTRONIC 4WD" emblems?
Aerostar Ford Aerostar
Old 09-07-2009, 08:46 PM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
93nighthawk is gaining momentum as a positive member of FTE.
Today while cleaning and touching up the paint on my Aero, I kept looking up at my dismally dirty ELECTRONIC 4 wheel drive emblems. It got to the point that I picked at the plastic clear plate cover a little bit and it peeled away easily. (there was a ton of dirt in there) I wiped it off so now it is clean, but the ELECTRONIC section is worn off in spots. So I have a couple questions/issues.
First, can I just use some paint to re-fill in the ELECTRONIC letters that are worn off?
And two, and suggestions on how to re-attach the clear plastic cover? I slapped it back on and it seems to be holding, but that might be a different story at 65 mph.
Thanks for your ideas and help!
Old 09-08-2009, 02:34 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.xlt4wd90 is gaining momentum as a positive member of FTE.
Can you find paint that matches that color? I would try an epoxy paint so it sticks hard, and so whatever glue (CA? clear epoxy?) you use on top of that will have a good foundation to grip onto.
Old 09-08-2009, 09:00 AM
Bear River
Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Those emblems were originally vacuum metallized, not painted. There is no paint that will look the same. You could try doing in is some chrome paint. To bond the cap on, I would recommend a clear non yellowing epoxy.
SuperDutyScaler
1999 to 2016 Super Duty
04-14-2017 08:21 PM
SLDNX
12-18-2016 07:29 PM
civicmindeddogooder
19
04-10-2016 12:19 PM
dlb.motorman
25
09-25-2011 07:58 PM
fordcoop
10-05-2005 10:00 AM
Quick Reply: How to restore "ELECTRONIC 4WD" emblems?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
