Rough Idling
I towed the trailer to the track last night and while waiting to get in the gates, i shut the truck off. Well when I started it back up the think was running, but had a weird vibration. The whole truck was shaking really bad. Power is the same though.
So today I popped the hood to look and no UVCH were burned or anything like that, it had good oil, nothing out of place there. SO I start it, and look and the water pump pulley is loose...and moving all around... I tried to tighten the 10mm bolts but they were all tight, so now my question is, the fan clutch nut, maybe its not tight. I am going to try and tighten it, but any other ideas? I know the exhaust is not hitting the cab, checked that last night.
Thanks
Im thinking it might be transmission related, because at around 2400-3100 RPM i can feel a bad vibration on the clutch pedal.
I know I Have a SMF, but i know the tranny needs new sycros in 1st to 2nd gear...
Wondering what else could have been damaged to make a vibration like this...
