Flipping Belt!
Old Dec 31, 2003 | 08:13 AM
Beast12's Avatar
Beast12
Thumbs down Flipping Belt!
I just replaced 3 belts on my truck in signature. I only replaced them because one had a big chunk out of it and was cracked and I had just bought the truck so I didn't know how old the other belts were. So I thought what the heck, I'll change them. Well, all went well except a few days later I looked under my hood and my belt that goes to the power steering has flipped! So, I thought, oh well, MAYBE I didn't put it tight enough. So I tightened it up and went on my way. Next day I looked again and it flipped again?!?! Weird. The belt sticks up a spec out of the power steering pulley. So I was thinking maybe I need to get a factory belt because maybe it will seat more flush? Also, all m pulleys are lined up and all is good. I just think it's the belt.
-Matt
Old Dec 31, 2003 | 11:46 AM
jwtaylor's Avatar
jwtaylor
Thats odd, I don't think I have heard of a belt flipping over. I am interested in finding out what the cause would be. Good luck getting it all lined out, later
Old Dec 31, 2003 | 12:27 PM
TheWiz427's Avatar
TheWiz427
I have seen it happen before make sure their tight and check your pulley alignment. Its also possible you have the wrong belt or theres a bad spot in the belt.
Old Jan 1, 2004 | 07:51 AM
fonefiddy's Avatar
fonefiddy
Either you have an alignment problem, or check out the crank pulley.
Old Jan 1, 2004 | 09:21 AM
Beast12's Avatar
Beast12
I don't think I do. The old belt was perfectly fine and worked except it had cracks in it. I thought I mine as well replace all three. I think it's because the belt sticks out of the power steering pulley a spec. It sticks up about 1/8 of an inch. And it's not that thick of a belt in the first place. I will keep you guys updated.
-Matt
Old Jan 1, 2004 | 11:55 AM
TheWiz427's Avatar
TheWiz427
That sounds like you have the wrong belt! It should'nt stick up out of the groove like that.
Old Jan 1, 2004 | 12:27 PM
Beast12's Avatar
Beast12
That's what I am thinking. Stupid Canadian Tire. Guess I will have to go to the dealership. Figures, it's the very back belt so I have to take ALL the belts off to replace it! DOH!
-Matt
Old Jan 1, 2004 | 04:33 PM
TheWiz427's Avatar
TheWiz427
I hate it when that happens!
Old Jan 2, 2004 | 02:51 PM
Beast12's Avatar
Beast12
Well, I looked at it again today. I guess it did look like my power steering pulley was of a spec. So I kind of adjusted it a bit. I put the old belt on and started the truck up. It flipped again. So I adjusted it a bit more. Started the truck up and it came off! It even took the other 2 belts with it! So, my dad has a box of belts and I found one that would fit on. I put it on and it worked. The belt is exactly the same. Weird. Maybe the old belt was screwed up and not straight from driving it for so long while it was flipped. I guess I will see what happens.
-Matt
P.S. I was "tapping" on my smog pump to loosen the belt and when I hooked the belt back up and started the truck back up it is making a kind if ticking noise (the smog pump is making the ticking noise). Any ideas? I am "allowed" to hijack my own thread!
Old Jan 3, 2004 | 12:11 AM
Ryan50hrl's Avatar
Ryan50hrl
gotta love serp belts
Old Jan 3, 2004 | 08:34 AM
TheWiz427's Avatar
TheWiz427
I'm not sure about the smog pump i have heard them tap before but i would definitely keep an eye on it for a while.
He does'nt have a serpentine belt Ryan, However they can be a pain too.
Old Jan 3, 2004 | 10:03 AM
Beast12's Avatar
Beast12
He's saying that the serpentine belts are sooo much better. I agree. I changed 2 serpentine belts on two different trucks in like 8 minutes. So much easier. Mmmmmmmmm...serpentine belts. I will let you know about that air pump. Kinda has me frustrated........Thanks guys!
-Matt
Old Jan 3, 2004 | 10:17 AM
TheWiz427's Avatar
TheWiz427
Oops i don't know why i read that wrong.
Old Jan 3, 2004 | 12:56 PM
Beast12's Avatar
Beast12
LOL! I love your smiley guys! The ones on here are getting boring for me.....except this guy that I always use when talking about Chebbies! Hehe!
-Matt
bulla
38
Jul 16, 2019 03:02 PM
Big Skier
31
Feb 27, 2019 07:21 AM
CoreLokt
Mar 14, 2016 06:13 PM
bkgeig
34
Aug 13, 2012 07:41 PM
3speed
Apr 1, 2011 11:44 AM
