Egr
Old Aug 24, 2009 | 05:20 PM
robby995's Avatar
robby995
Thanks for all the good info. how do you clean the valve and make sure the cooler dose not go out? What oil should i be running?
Old Aug 24, 2009 | 05:24 PM
slowmans's Avatar
slowmans
Originally Posted by unrulee
My stock '05 doesn't throw a CEL. But I plugged it back in after learning that the turbo vanes are locked into one position by the ecm when you unplug the egr valve.
maybe your 05's engine has an 04' build date? I know the 03-04 motors usually wont therow a code but the 05-07' usually will?maybe your special
Old Aug 24, 2009 | 05:27 PM
slowmans's Avatar
slowmans
un plug it, unbolt the 2 screws and turn 1/8 turn to the left, some folks use channell lock pliers some people thread wire throught the bolt holes and others just give it a good yank and it comes right out.... get some carb cleaner and remove the orings, spray it down good, but make sure you dont get any carb. cleaner in the 2 weep holes at the top of the valve! put orings back on reinstall and enjoy!
Old Aug 24, 2009 | 06:02 PM
KRDiesel's Avatar
KRDiesel
The "limp mode" limits boost and fueling under heavy load to limit NOx. 03-04 will not set a light, except cali trucks. it also depends on what flash level you are at.
BTW this was verfied by Matt at Spartan.
Old Aug 24, 2009 | 06:05 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
AH-HAH! I knew I read it somewhere!
Old Aug 24, 2009 | 11:54 PM
getbent403's Avatar
getbent403
so with the egr vave unplugged,, the valve stays shut?? is it an fully open/ fully closed type of valve or is it all over for certain conditions?
Old Aug 25, 2009 | 04:26 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
You have to unplug it with the engine off or it will remain open. AFAIK it is either open or closed.
Old Aug 28, 2009 | 10:22 PM
5nahury's Avatar
5nahury
oil cooler flush
How difficult is it to pull oil cooler and flush? Trying all the simple stuff first to keep truck running cool while towing 5th wheel.
Old Aug 29, 2009 | 09:08 AM
janton01's Avatar
janton01
It requires a lot of dismantling as it is at the front of the engine under the area that the intake manifold covers. Quite a lot of labor. When mine was done we just replaced the cooler and its screen rather than take a chance on any further problems with it. Also put on the new egr cooler (mine is the round one) but put a freeze plug in the end of it so no exhaust gases pass through it anymore. system looks perfectly normal and throws no codes or cel.
Old Aug 29, 2009 | 02:21 PM
5nahury's Avatar
5nahury
oil cooler clean
OK, that doesn't sound simple. Maybe I'll wait.
lilrobo
Jun 28, 2014 05:55 PM
lilrobo
67
Oct 29, 2013 05:41 PM
lilrobo
26
Oct 8, 2013 07:42 PM
lilrobo
56
Jun 30, 2013 02:05 PM
Robs06SuperDuty
Maryland Chapter
Jan 21, 2007 02:21 PM
