straight axle rebuild?
Old Aug 20, 2009 | 09:53 PM
wicat3's Avatar
wicat3
i did a search and didn't find anything so here it goes. I have a 1949 f1 and want to upgrade the old straight axle. I know it needs king pins and figured while i was at it might as well go through and do the tie rod ends and the tie rod. Anything else i should do and what upgrades to help it handle better would be recomened? Also if i wanted to freshen it up, mabe paint it?
Old Aug 21, 2009 | 04:38 AM
jaye's Avatar
jaye
Check the spring perches or brackets after years of abuse the rivets get loose or corrode off. If they are broken missing, etc you can replace them with grade 8 bolts. You can also repack the bearing and change the brack shoes and brake parts i.e. springs. Almost forgot since you have the axle off check the leaf springs to ensure they are not cracked you may also need to grind off rust build-up. The brass fitting and hole in the main spring may be oblong if the truck was really used if this is the case you may need new main springs or just the bushings which a shop can press in for you.
Old Aug 21, 2009 | 12:11 PM
Huntfamily53's Avatar
Huntfamily53
I'm doing all this on my 53 now too. I am replacing king pins, rebuilding drag link ends and replacing tie rod with a HD one with new tie rod ends.
I am going to paint my axle with copper hammer tone finish and the other steering arms, etc black. I am going to sell off my stock drums and use the money to put on discs. While I have everything apart I am doing as jaye suggests and doing my springs as well. I am removing every other leaf and putting in poly liner in between. This should make the ride nice and lower me down a few inches. I am replacing the main leaf in each pack as well.
When I took my springs apart I found that the brackets were messed up. A good member on here sent me a used set of of his so I am going to use those (Thanks again Jack!).
Finally, I am replacing the ubolts that hold the axle on because my spring pack is shorter and I heard you should not reuse the bolts anyway I am then adding 4 degree caster shims under the axle.
Its the old saying that one thing leads to another, but I didn't want to be left with a weak link in there and having to do it all again later.
Old Aug 21, 2009 | 03:14 PM
4tl8ford's Avatar
4tl8ford
Do the spring bushings and bolts along with the things mentioned above.
Old Aug 21, 2009 | 04:22 PM
wicat3's Avatar
wicat3
i will probally be taking the front end to a shop to do the king pins so ill make sure to check the bushings. brakes should be good since i put a disc brake conversion on. how about those steering stablizers? do they work or worth the money?
Old Aug 21, 2009 | 04:39 PM
53rat's Avatar
53rat
I put a front swaybar on my 53 and it made a huge difference well worth the money.
Old Aug 21, 2009 | 04:45 PM
wicat3's Avatar
wicat3
were did u get the kit to do it? I have only found one place so far
Old Aug 21, 2009 | 05:02 PM
53rat's Avatar
53rat
If your reffering to the swaybar...Ebay. Here's a pic. Remember this is a 53 F100
Old Aug 21, 2009 | 05:36 PM
wicat3's Avatar
wicat3
yea that looks like the same set up ive found in a magizine im going to have to hit up ebay and see what happens thanks
Old Aug 21, 2009 | 06:49 PM
4tl8ford's Avatar
4tl8ford
They make a Swaybar for the real Trucks also
jdunbar
Aug 30, 2021 05:17 PM
ddiaz12
32
Sep 26, 2014 05:07 PM
F-350 Mud Digger
Aug 14, 2010 02:51 PM
john061543
May 24, 2010 09:06 PM
