Scrub Line
Old May 23, 2010 | 05:59 PM
john061543's Avatar
john061543
Scrub Line
I put a Mid-Fifty's dropped front axle in my '55 and used the tie rod end "drops" to get the tie rod to fit. Now the tie rod grease fittings are below the scrub line. In fact, I discovered I had a low front tire when I smelled burning rubber, as the tire bulge was rubbing against the tie rod end!
Has anyone else encountered this problem? What, if anything, did you do about it?
Thanks, John
Old May 24, 2010 | 01:43 AM
Julies Cool F1's Avatar
Julies Cool F1
I haven't done the drop spindle thing. The little bit I wanted I got from reverse eye springs.
But I'll bump this back up for you.
Old May 24, 2010 | 08:42 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I'm not sure I fully understand why the tie rod end is now in contact with your tire but I would think some simple spacers on the front wheels would correct the problem. If that isn't enough then new wheels with more positive offset might be needed...
Old May 24, 2010 | 09:05 AM
john061543's Avatar
john061543
The tie rod end is well clear of the tire when the tire is fully inflated. It only touches when the sidewall bulges from loss of air.
Old May 24, 2010 | 08:59 PM
GreatNorthWoods
That's a little close for comfort. I think I'd want to space it out a quarter of an inch at least....
Old May 24, 2010 | 09:06 PM
john061543's Avatar
john061543
My problem isn't that the tie rod end will hit the tire if the tire is low. The problem is that the tie rod end is lower than the edge of the tire rim. If I blew a tire and it peeled off the rim, the tie rod would be on the ground!
Not sure how to remedy this as all the components - axle, springs, disk brakes, tie rod - were installed correctly. Should the tie rod be installed above the leaf springs, rather than below?
John
SC_Dave
Mar 7, 2014 07:26 PM
Schuyles
Jan 5, 2014 09:57 AM
John R. Thomas
23
Oct 28, 2013 02:41 PM
Front1/4
1947 and Older Ford Trucks
Dec 19, 2012 08:33 PM
jjaramz
Jan 4, 2009 05:07 PM
