tie rod end torque?
Old Dec 15, 2009 | 10:40 PM
jdunbar's Avatar
jdunbar
tie rod end torque?
just installed new tie rod ends. couldn't find torque until i looked here!. i torqued them to 80 ft lbs. can someone tell me if being that tight will be of any concern? just want a piece of mind. thanks
2004 f250 6.0 diesel 4x4 (straight axle)
Old Dec 16, 2009 | 06:41 AM
DSMMH's Avatar
DSMMH
I just changed the steering gear in my X and I believe the correct tie rod nut torque is 69 Lbs-Ft. Since tie rod nuts use cotter pins the correct procedure is to torque the nut to 69 Lbs-Ft. If the tie rod nut cotter pin slot does not line up with the bolt hole then tighten the nut until the next nut cotter pin slot lines up with the bolt hole. Install cotter pin and you are done.
DSMMH
Old Aug 30, 2021 | 05:17 PM
reallymattgray's Avatar
reallymattgray
Close...
41 ft. lbs. for the Adjusting sleeve clamp nuts
67 ft. lbs. for all tie rod end castle nuts.
200 ft. lbs. for the nut holding the pitman arm to the steering box.
1999-F150
1997 - 2003 F150
Oct 4, 2022 12:59 PM
Fishin76
Oct 29, 2010 12:52 PM
balingwire
Dec 22, 2008 03:19 PM
GeneStoner
Feb 3, 2005 10:37 PM
