Sponsored by: Real Truck
oil pan removal
Old Aug 20, 2009 | 08:05 PM
therigwelder's Avatar
therigwelder
oil pan removal
i have a 95 powerstroke,i have the tranny and flywheel out for clutch replacement and want to replace leaking oil pan seal and dipstick.does the engine still have to come out?or can i unbolt the pan and slide it back?
Old Aug 20, 2009 | 08:20 PM
F350-6's Avatar
F350-6
You can ask down in the 94 - 97 7.3 section to be sure, but I'm thinking you can't pull the pan without either removing the motor or removing the crossmember (not recommended)
The newer trucks use RTV instead of a gasket, so that is possible to repair without pulling the motor, you'd just need to let the oil drain for several days after loosening the oil pan. The dipstick tube leak can also be repaired without removing the pan, but if the pan is rusted through and leaking through pin holes, then it's time for the motor to come out.
maverick600
May 21, 2017 03:21 AM
Ol Red 75
Sep 15, 2011 11:23 PM
Jermafenser
Aug 10, 2008 10:14 AM
oxfordgt
Nov 7, 2006 09:16 AM
psf
Aerostar
Dec 26, 2004 03:32 PM
