Door codes..
Old Aug 20, 2009 | 02:01 PM
truckdriver_mn1984's Avatar
truckdriver_mn1984
Door codes..
Ola! hey guys. Well i got another truck.. I picked up another 87 F150 reg cab 4x4 with a auto and a 5.0. Pretty much the same as mine i posted on here even close to the same color.
I cant match up the door codes due to my other one i cant read but the sticker on my new one is in good shape.
This truck looks tougher than mine like the springs and axels and what not. So. I wanted to post the entire sticker on here and see if anyone can explain it all to me. I know what the gross weight is and all.. and the WB. Just wondering if its a heavier 150.
Ok so here it is,
GVW is 6250 lbs,
Rear is 3750lbs,
front is 2950lbs.
Type, truck
1C 1G
Spring
C7
Type
axel
19
WB
133
GVW
F142
body
TD4
Trans
T
Thanks alot guys
Jared
Old Aug 20, 2009 | 03:07 PM
F150xlt's Avatar
F150xlt
Here ares some of the answers.
Type 3 If you mean Tape 3 External Tape Stripe is Medium Charcoal /Red Orange
Axle 19 is 3:55 ratio
F142 is F-150 4x4 GVWR 6250 lb, 133" wheelbase
TD4 is Seats are cloth, Flight bench seat, Canyon Red, Regular cab Style side Pickup.
Trans T is a AOD
Old Aug 20, 2009 | 04:22 PM
truckdriver_mn1984
Ok cool thanks! would the AOD work if i carb the motor? The computer is gone along with alot of the EFI components.
Where could i find info/kits/help with carbing a efi truck?
Old Aug 16, 2010 | 08:36 AM
presidentsdad's Avatar
presidentsdad
Hey...can I get some assistance as well? I cannot find all the codes either....
WB - 155 (155" Wheelbase)
Brake B (?)
Body R64 (?-I'm assuming supercab longbed)
Trans - E (E4OD)
Axle C5 (4.10 LS)
TAPE 3 (?)
Springs 74A (?)
Exterior paint codes
UA - Ebony
FN (?)
Old Aug 16, 2010 | 08:41 AM
Conanski's Avatar
Conanski
Yes you just need a Lokar TV cable and bracket to attach it to the throttle linkage.
DSparksF250
Oct 25, 2016 08:39 AM
Timon
1983 - 2012 Ranger & B-Series
May 17, 2016 10:51 AM
abosely
Mar 27, 2016 05:37 PM
cpye2
Jul 24, 2013 07:36 AM
amchastain
Jul 23, 2005 09:44 PM
