volare IFS
Old Aug 20, 2009 | 12:53 AM
bbussman40's Avatar
bbussman40
volare IFS
I'm thinking of installing a volare suspension this year, the engine is a ford 302 with a front sump. will this interfear with the suspension crossmember?
The other item is the power steering pump.
Do I need the chrysler pump or just use the ford pump.
thanks
Old Aug 20, 2009 | 05:55 AM
ferguson777's Avatar
ferguson777
You'll need a rear sump. You can get one off a truck or a van.
I'm using the Ford pump with an adjustable pressure valve I picked up from RB 's. I beleive most people are using the Ford pump as is.
Try to get a " Volare" unit from a V8 equipped car to ensure you get the thicker torsion bars.
Regards,
Old Aug 20, 2009 | 06:22 AM
raerjim's Avatar
raerjim
Fergie, what valve is that? I assume you reduce the pressure. To what? What is RB'S? What's the square root of 11? haha
Old Aug 20, 2009 | 06:31 AM
BACAGrizz's Avatar
BACAGrizz
That would be 3.32.
Old Aug 20, 2009 | 11:28 AM
bbussman40's Avatar
bbussman40
front sump
Thanks, I wasn't sure about the pan. I guess I have to find the right oil pickup tube and pan. Do the rear sump pans have a dip stick built into them? Right now I have the toyota sterring box and it seems a little hard to turn the steering wheel. You can turn it with one hand but not like my dodge pickup.
I do enjoy all the Q & A on this site.
Dennis
Old Aug 20, 2009 | 11:41 AM
ferguson777
I did a short discussion thread on the adjustable valve in here about 3 years ago...but when i get home tonight I'll get the proper brand name and part # for it. The valve has a **** on it that lets you adjust the pressure to the box from full down to whatever.
One of the hot rod mags ran a short " tech article" on it back then as well.
We tried to do an in depth analysis of the pressure output of the various mfgr's power steering pumps about 3 or 4 yrs ago but we ( the forum) just couldn't seem to get the data.
RB's was an outfit that sold hot rod parts - (blue and peach coloured cover on their really thick catalog) but I think they went out business last winter. They didn't make the vavle, they only sold it, so I'm sure other still do. Not even sure if you really need it, but I love spending money on parts.....
Dip stick in pan or block ? Can't remember - will check when I get home tonight.
Old Aug 20, 2009 | 05:11 PM
flatheadjohn's Avatar
flatheadjohn
I have a rear sump pickup tube that I believe was out of a Bronco (289 or 302) Now all you'd have to do is find a pan! Let me know if you're interested.
Old Aug 20, 2009 | 06:20 PM
CharlieLed's Avatar
CharlieLed
You don't necessarily have to use a rear sump pan, it all depends on your motor mount setup. Since you are installing this IFS new then you'll also have to install the mounts so you can put them where you need them. Here's a pic of my truck with a front sump pan...
Old Aug 20, 2009 | 06:26 PM
Okiedokie's Avatar
Okiedokie
Mustang [late 80's/early 90's] 5.0 had a dual sump pan that worked for me with Volare. Joe
Old Aug 20, 2009 | 07:13 PM
raerjim's Avatar
raerjim
dang that looks good, Chuck. What rotors are those?
Old Aug 20, 2009 | 07:26 PM
CharlieLed's Avatar
CharlieLed
They are aftermarket Volare drilled and slotted rotors. I believe I bought them out of a mail-order shop in L.A.
Old Aug 20, 2009 | 07:52 PM
ferguson777
My 5.0 is from a 1990 F150 and it has the dipstick coming out of the block.
That adjustable power steering pressure valve that I got from RB's is actually made by/for Heidt's Hot Rods and they currently advertise it for $85.00 They actually call it " Adjustable steering pressure valve " As I said, not sure if it's even necassary, but what the hay.....
Old Aug 21, 2009 | 03:07 AM
raerjim's Avatar
raerjim
I seem to recall that old thread, but Idon't know if my Ford pump makes too much pressure or not enough. Sometimes when good and hot, steering wheel is harder to turn than usual...
papabills54
Jan 29, 2015 10:02 AM
sid318
Mar 29, 2009 10:20 AM
675080
Oct 4, 2007 09:42 AM
53choptop
18
Apr 30, 2003 10:50 AM
Kenny
Jun 26, 2002 12:33 AM
