stay away from Gabriel. they really like to rust through in short order. If you want bang for the buck the Monroe Gas matic LT ($22 each at advance) ride very nice on the front of my 99. on the rear I opted for the SensaTrac load leveler shock with the coil over assist. about $120 for a pair. Kyb makes a pretty good shock in the price range.
I will stay away from Gabriel. Thanks for the tip. Did you have them installed or did you do it yourself? If you had them installed, what did you pay for the labor?
The best shocks and very commonly recommended here are the Bilsteins. Extremely well made shock. I have learned to stay away from Monroe shocks. We have a section of road that is under construction, so its very bumpy. When I take my mom's '92 Aerostar with Sensatraks, it gets all bouncy to the point where it will sometimes bottom out. My bro's '97 Aerostar has just worn out shocks and it does the same thing. I have had KYB's on my van for the last 60,000 miles, and they still handle this same stretch of road just fine. Even when i have a full load it won't bottom out.
The Bilseins are a slightly better shock than the KYBs. They have a smoother ride.
I would seem to think the bottoming out van has worn springs or other suspension parts. But maybe a bad set?
As for the Bilstein, it's a very good shock, but its around triple the price. And for a 16+ year old street driven truck, I would think the best shock valu e would still be the Monroe or KYB.
I'm going to be contrary here and advise against the KYB's. I found they wore out on the front end way too fast. The rears last forever unless you haul heavy loads - but on the front they wore down too fast for me.
I might try for Bilsteins, but I was looking at Monroes as a starting point.
If you have had them on your truck then your observations are better than mine. I have been using KYB GR-2 Struts on my Cougar on several recommendations from other Cougar/Contour owners with lowered cars. The Truck shock may very well be a totally different animal.
I won't condemn the KYBs for all Rangers, but at least for the 2000 they don't/didn't hold up at all. I'm not overly fond of the 2000 Ranger front-end suspension anyway - in my mind it's not robust enough.
1) Koni- Excellent for racing applications- overpriced for street applications
2) Tokico, QA1 & Bilstein- A very good shock for street/strip applications. If you are running very stiff tires on the street (such as Bridgstone that are 100% steel belted or tires with profiles shorter than 50 series), these provide the extra give that you need for both comfort & stability
3) KYB- A very good shock for street/strip applications. If you are running a softer tires on the street (such as BFG that are a mix of steel & nylon belted or tires with profiles not shorter than 50 series), these provide the extra stiffness that you need for both comfort & stability. The GR-2’s are the equivalent to the Edelbrock IAS automatic adjusting units. Overall, stiffness between the Gas-a-just and the GR2’s are the same, the difference is the GR-2's valving which stiffens things up from a oem setting to that of the Gas-a-just units.. Best shock for the $/best price typically found at Performance Suspension Technologies (PST) and typically about 1/3 less than Bilstein.
4) Gabriel- A very nice good quality HD OEM replacement type unit.
As for the Bilstein, it's a very good shock, but its around triple the price. And for a 16+ year old street driven truck, I would think the best shock value would still be the Monroe or KYB.
The road has some crest and dips, and at 55 mph, which is the work zone speed limit, it will set the vehicle into bouncing. One of the primary functions of the shocks is to arrest the bouncing. If the springs were worn out, the vehicle would ride low. The Monroes were good for maybe a week before they worn in, at which point they were only moderately better than the old worn out shocks.
The KYB GR-2 is a great shock. Myself, I am running the Gas-A-Just because I handle a lot of weight.
