Factory rectangular / round fogs...Which are better?
Old Aug 19, 2009 | 08:36 PM
ScubaCat's Avatar
ScubaCat
The 04/05s have the longer rectangular fogs and the 06+s have the round...Which put out a better throw of light?
I like the style of the rectangular ones better...if they are better, is it a direct swap with a new bumper valance and lights?
Old Aug 19, 2009 | 10:53 PM
Fishin76's Avatar
Fishin76
The 04 rectangular fog lights are integral to the bumper, there is no holes in the lower valance on that model year.
A whole new bumper with the lights would be needed. I believe.
Tylus, correct me if I'm wrong dude.
Old Aug 19, 2009 | 11:31 PM
442w30's Avatar
442w30
Have/had both styles, neither one is very effective... look good but that is really about it, IMHO
Old Aug 20, 2009 | 12:25 AM
ford390gashog's Avatar
ford390gashog
The rectangle ones do not work well. The round ones work pretty well as long as you install the mustang headlight bulb.
Old Aug 20, 2009 | 12:45 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Round have a slightly better light pattern since the beam is focused in a cone
but the difference is really subjective. whatever pleases your eye the most. I personally like the round the best because it flows with the body lines the best IMO...and it ties in with the headlights as well.
now, if you have a 04/05 and want a 06+ bumper, it is a easy swap. You need a few parts though.
06+ bumper with pre-cut holes
06+ bumper mounts (x4)
switch parts around if you have a 06+ and want 04/05 style lights
lots of guys have done the swapout. Once you have all the bumper mounts, it's a simple matter of unbolting the old, and putting the new on. Nothing needs to be adjusted or finagled to make it fit.
Old Aug 20, 2009 | 09:40 PM
Fishin76's Avatar
Fishin76
I'm just the opposite. I like the 04 style. they seem to project light a little wider to the sides, (good for seeing DEER in the ditches). as for fog, yeah, not that good. Luckily, I only have fog once in a while, and its usually at cab level it seems. Deer, i have that threat all year long.
Old Aug 21, 2009 | 05:15 AM
klook's Avatar
klook
Fog
We have the thickest fog in the world and more of it then anywhere else, I have never seen factory fog lamps that were effective. The same goes for driving in heavy snow storms although we do not have more of that then some other places. You would need a second Alternator and about four Big lights to cut heavy fog, and then it would be easy to outdrive the lights. I think they just look cool and I dont have a preference.
Old Aug 21, 2009 | 02:21 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I only have fogs for regular night-time driving.
They light up that area immediately under the bumper where the heads leave a dark spot.
