Sponsored by: Real Truck
No panic yet.
Old Aug 19, 2009 | 08:07 PM
SwanyRiver420's Avatar
SwanyRiver420
No panic yet.
Just pulled back into work after going to dinner to find my truck gearing higher than normal. I look down on my dashboard and see the check guages light on along with the tow/haul light flashing on and off. Then I notice that the tranny temp guage is all the way at the bottom. This seems to me like a sensor problem to have all these things go wrong at once but wanted a second opinion, has anyone else had this happen before?
2004 f-350 crew
6.0 75K
Old Aug 19, 2009 | 10:06 PM
Mustang6147's Avatar
Mustang6147
I have never had that happen, but have read many posts on here that did have it happen.
The causes range from a plugged tranny filter, to low on fluid, to a bad sensor in the tranny or a bad selenoid. I think one guy had a wireing harness issue to??
I know one thing, if and when it happens to me, right to the dealer or a tranny shop I trust.
Old Aug 20, 2009 | 08:24 AM
Sarge261's Avatar
Sarge261
Sounds to me like there is a problem with the TFT or the wiring going to it. With the Tow/Haul light flashing there should be some codes stored in the TCM, so I would start there with a code reader from a parts store if you dont have one.
Sarge
Old Aug 20, 2009 | 10:09 AM
SwanyRiver420
Dealer said it would be over a week for them to fix it (they have only 1 tranny person working), so I got a new temp sensor and some mercon sp and she is parked in the garage to cool so I can drain the tranny and drop the pan to replace the sensor. If all goes well that is the majority of the replies that I have gotten to solve the problem.
Old Aug 20, 2009 | 10:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
Dealers don't usually fix much when it comes to transmissions, they usually will give it a quick "once over" and then recommend you purchase a rebuilt transmission.
Old Aug 20, 2009 | 11:51 AM
krewat's Avatar
krewat
Swany, let us know how it turns out.
Old Aug 20, 2009 | 01:24 PM
senix's Avatar
senix
dealer will just do a swap, if under warranty that is one thing. If on your dime, get it rebuilt.
Old Aug 20, 2009 | 01:36 PM
SwanyRiver420
Knock on wood, that was pretty easy.
11/2 hours, pretty straight forward. Just like the guys said , when you pull the sensor out more fluid comes gushing out so dont have your head under it when that happens. Only have driven it 20 miles but it should have showed if there was an more probs. Thanks to all.
75$ sensor
10 qts of SP for 50$
Saving over 500$ Priceless.........
Old Dec 14, 2010 | 08:38 AM
SwanyRiver420
Update
Not such a bad backyard mechanic afterall.
Still running like a champ, and no leaks.
Kelloyan
Jan 24, 2013 06:52 PM
chosen1608
2004 - 2008 F150
Jun 17, 2010 12:18 PM
strokin'_tatsch
Nov 5, 2009 07:16 AM
cbfomoco
Oct 22, 2005 04:05 PM
65style
Sep 21, 2005 07:17 PM
