torque specs for brake job?
I'm reading https://www.ford-trucks.com/article/...e__Part_I.html
but don't see any torque specs. I'm doing front and rears today.
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>lb-ft</TH><TH vAlign=bottom align=middle>lb-in</TH></TR><TR><TD vAlign=top align=left>Disc Brake Caliper Pin Bolts</TD><TD vAlign=top align=middle>56</TD><TD vAlign=top align=middle>42</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front Brake Hose Bolt</TD><TD vAlign=top align=middle>35</TD><TD vAlign=top align=middle>26</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front Disc Brake Caliper Anchor Plate Bolt (F250, F350)</TD><TD vAlign=top align=middle>225</TD><TD vAlign=top align=middle>166</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front Disc Brake Caliper Anchor Plate Bolt (F450, F550, Motorhome Chassis)</TD><TD vAlign=top align=middle>400</TD><TD vAlign=top align=middle>295</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front Wheel Hub Extender Nuts</TD><TD vAlign=top align=middle>176</TD><TD vAlign=top align=middle>130</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Front Disc Brake Rotor Shield Screws</TD><TD vAlign=top align=middle>11</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>98</TD></TR><TR><TD vAlign=top align=left>Spindle Nut <SUP>a</SUP> </TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>—</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 border=1><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>Lb-Ft</TH></TR><TR><TD vAlign=top align=left>Disc brake caliper pin bolts — F250/F350 with Ford and Dana axle</TD><TD vAlign=top align=middle>36</TD><TD vAlign=top align=middle>27</TD></TR><TR><TD vAlign=top align=left>Disc brake caliper pin bolts — F450/F550/Motorhome with Dana axle</TD><TD vAlign=top align=middle>55</TD><TD vAlign=top align=middle>41</TD></TR><TR><TD vAlign=top align=left>Caliper banjo bolt</TD><TD vAlign=top align=middle>50</TD><TD vAlign=top align=middle>37</TD></TR><TR><TD vAlign=top align=left>Rear wheel disc brake adapter bolts — F250/F350 with Ford axle</TD><TD vAlign=top align=middle>203</TD><TD vAlign=top align=middle>150</TD></TR><TR><TD vAlign=top align=left>Rear wheel disc brake adapter bolts — F350/F450/F550/Motorhome with Dana axle</TD><TD vAlign=top align=middle>135</TD><TD vAlign=top align=middle>100</TD></TR><TR><TD vAlign=top align=left>Rear wheel disc brake shield bolts — F250/F350 with Ford axle</TD><TD vAlign=top align=middle>11</TD><TD vAlign=top align=middle>8</TD></TR><TR><TD vAlign=top align=left>Rear wheel disc brake shield bolts — F350/F450/F550/Motorhome with Dana axle</TD><TD vAlign=top align=middle>15</TD><TD vAlign=top align=middle>12</TD></TR><TR><TD vAlign=top align=left>Rotor-to-hub bolts</TD><TD vAlign=top align=middle>127</TD><TD vAlign=top align=middle>94</TD></TR><TR><TD vAlign=top align=left>Disc brake caliper anchor plate bolts — F450/F550/Motorhome (with forward-of-axle brake calipers)</TD><TD vAlign=top align=middle><SUP>a</SUP> </TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Stone shield nuts</TD><TD vAlign=top align=middle>62</TD><TD vAlign=top align=middle>46</TD></TR><TR><TD vAlign=top align=left>Disc brake caliper anchor plate bolts — F450/F550/Motorhome (with rearward-of-axle brake calipers)</TD><TD vAlign=top align=middle>400</TD><TD vAlign=top align=middle>295</TD></TR><TR><TD vAlign=top align=left>Disc brake caliper anchor plate bolts — F250/F350</TD><TD vAlign=top align=middle>173</TD><TD vAlign=top align=middle>128</TD></TR></TBODY></TABLE>
Show off
Nice job, tried to rep you!!
No Problem, I thought you in came in with more info.. I was just having fun, but then found out the rep police kept me from paying some respect.
Any idea how much fluid is required for a complete brake fluid flush? I have a liter of Motul 5.1 I want to use, but if it takes more than a liter, I'll have to use the RBF 900
didn't see anything here:
https://www.ford-trucks.com/article/...Made_Easy.html
