I just got a '91 F150 ext cab 5.0L Automatic for $500 body in good shape and interier is great shape.
But Its Having Issues when it gets a Bit Warm loses power and wont restart when
its warmed up,have to wait least a hr for it to restart!going to pull codes this morning.
It was parked for awhile so it can be almost anything. Its also shifts sluggish when warmed up the longer its run, makes me suspect a vacuum issue, when it wont start the coil has spark so do the plugs but it acts like its not getting spark! suggestions anyone?
Thanks in Advance!!!!
Check your fuel pressure with a gauge.
Do you have two tanks? If so does it do it on the other tank?
Also you may want to change the fuel filter but sounds more like a fuel pump.
