need help with ignition system problem
had the ingition module tested twice (ok), replaced the battery, battery cables,
relocated battery - cable to a better (less oily) location on the engine, etc..., I replaced things one at a time thinking I would find the bad part but never did.
the symptoms are- starts great when cold. runs for 5 to 20 miles fine, lurches some but not real bad. The problem comes when it stalls trying to pull away from a stop, or I shut it off. Then it won't start. When I first started trouble shooting it, it had spark at first then after some cranking lost spark. Now it has no spark from the first attempt of restart. After about 4 hours it starts fine.
If I try to start in 4 hours, I have to charge the battery. If it sits for 10 hours I don't have to charge the battery.
My 91 has a TFI-IV system which is sending error codes with key on engine off of 63 & 21. continuous codes are the same. I couldn't get run codes because I can't restart when warmed up. If I drive 100' it won't restart.
thanks,
91.mickey
Lastly, are you sure this is a no spark problem? Are you positive there wasnt a dim spark due to low cranking voltage and the problem lies with fuel delivery or the injector controll circuit? I'm not trying to say you havent diagnosed it correctly but you could really waste a lot of time and money thowing parts at something for a single simple failure.
I wish i could provide you with more input but based on your post you have and ignition module/hall effect/coil failure claiming that all are new. If you positive they are all not the culprit the only thing left is the wiring between them.
Hope that helps.
thanks,
91.mickey
Check the chassis grounds at the small post on the radiator support in front of the battery. The stock Ford arrangement is a little cheesy. Take the nuts off the post and shine everything up thoroughly. Get the nuts back on good and tight.
Check the PCM ground near the driver's side hood hinge. Give it a similar "shine it up" treatment. Double check your battery ground wire on both ends.
Check the screws securing the TFI to the distributor body. They need to be tight enough to get a good ground. Unfortunately you need the special tool or a thin-wall socket to do this.
Check that the distributor hold down bolt is tight.
Fixing the grounds is ultimately what fixed my problem.
Code 21 is normal for a KOEO test with a cold engine. Code 63 can be a symptom of bad grounds -- or likely just be a bad or mis-adusted TPS. This is not related to your "no spark" condition, unless it is another symptom of bad grounds.
thanks,
91.mickey
thanks,
91.mickey
Code 98 as a KOEO code (prior to the separator pulse) indicates a problem with the transmission EPC solenoid. Make sure you know the difference between KOEO codes and continuous memory codes when considering what to do about code 98.
The next time the truck won't start, check to see if it has spark. If there is no spark, pull out the gray SPOUT jumper plug next to the distributor. Try cranking the engine with the jumper removed. See if the spark comes back, the engine starts, or both. If removing the SPOUT jumper restores spark, then the computer is interfering with the ability of the TFI to feed PIP back into SPOUT. This plus code 98 as a memory code would suggest replacing the PCM.
The TFI is capable of generating spark on its own with the computer removed from the truck. In effect, removing the SPOUT jumper accomplishes this, from the TFI's point of view.
"Finding the starter bad" is suspicious. Often the act of removing the wires and installing the new starter corrects the real problem, that of high resistance connections from the battery. The "new starter" works great, but so would the old one if you put it back.
