EVP or DPFE problem on 92 4.9
Old Dec 23, 2002 | 12:14 AM
heathdaily's Avatar
heathdaily
Truck is a 92 F-150 4.9 M5OD.
Getting a code thrown. Happens when I wind up a little on the motor and let it coast down while still in gear. If I let it out of gear it doesn't seem to happen, except once or twice when I missed a shift and it saw a little more rpm than I normally like to run it at. Engine light always goes off after six seconds, every time.
KOEO test has system pass and when memory codes come up it shows a 327-EVP or DPFE circuit below min voltage. KOER test shows 172-HEGO shows system always lean.
Problem is the friggin chilton doesn't bother to say what a EVP or DPFE is! (chiltons suck) Does anybody know what they are so I can try to check them? Thanks!
Old Dec 24, 2002 | 12:09 AM
steve83's Avatar
steve83
Exhaust Valve Position - it's the white sensor on top of the EGR. A Haynes manual will tell you things like that, and how to test it with a multimeter.
Old Dec 24, 2002 | 03:27 AM
heathdaily's Avatar
heathdaily
Dug around in the egr section of the chilton and found a tiny little part on the "Pressure Feedback Electronic (PFE) Transducer". Sounds like the DPFE is a mis-print to me. No testing instructions, location, description, nothing. Not that you could depend on them anyway.
Learn from my mistake, Buy a Haynes instead.
Old Dec 24, 2002 | 07:45 AM
steve83's Avatar
steve83
[updated:LAST EDITED ON 24-Dec-02 AT 08:46 AM (EST)]Send me a real e-mail and I'll attach the MityVac manual to my reply. It has the test procedure for that sensor. Just be sure to put something specific in it to remind me what you want - I get a lot of e-mails.
Old Dec 30, 2002 | 10:38 PM
heathdaily's Avatar
heathdaily
I have not been able to find a DPFE or PFE or whatever valve. I am assuming that my truck does not use one. Which sorta makes sense, if I have the EVP then I don't need the other one. Like having a MAP sensor makes a MAF redundant.
Per the Chilton I tested the EVP sensor. It has 5.0 volts ref voltage, and with the key on and engine off, there is .41 volts between the other two wires. Supposedly it's good if there's less than .67 volts there.
Any ideas?
Only thing I can think of that might matter is that both cats are removed. The two pipes were Y-ed together after the O2 sensor and join into a 3" pipe that runs to the trans. crossmember where it goes to 2.75 I.D. until it hits the stock muffler.
That would definitely affect exhaust pressure, but as I don't (I think) have a PFE it shouldn't matter.
Old Dec 31, 2002 | 12:12 AM
steve83's Avatar
steve83
Yeah, I got an idea...
Stop spending all this time fighting your Chilton's manual, and spend $12 on a Haynes .
Old Dec 31, 2002 | 12:31 AM
heathdaily's Avatar
heathdaily
Man, I am so POOR right now. Christmas just about killed me. Got a job interview coming, but don't know how it'll turn out yet. When the money comes in I'll definetely grab a haynes. Probably gonna BURN the chilton.
Old Dec 31, 2002 | 10:30 AM
Racerguy's Avatar
Racerguy
The readings you are getting from the EVP might be right when you are testing it but you cant see what they are when it is actually working unless maybe you follow Steve's Mityvac instructions and actually check the output at different EGR openings. It is very common for the EVP to turn on the check engine light for a few seconds and then go off again. Just replace the sensor and see what happens. You might want to try borrowing one off a buddies truck to try it before you buy one. They only take a minute to replace.
Old Jan 2, 2003 | 10:50 AM
mgdhunter's Avatar
mgdhunter
SteelHorse4x4
Apr 9, 2017 12:12 AM
DBGrif91
Sep 9, 2013 05:21 PM
Tom92F150
24
Aug 31, 2010 08:29 PM
qman
Nov 17, 2004 09:08 AM
