6.0 Intercooler
Old Aug 19, 2009 | 12:03 AM
rat49f6's Avatar
rat49f6
i drove about 6 hours round trip and paid $150 for my 6.0 intercooler
Old Aug 19, 2009 | 04:31 AM
Adam0331's Avatar
Adam0331
I think I may do it or maybe see if he can meet me half way or something.
Old Aug 19, 2009 | 10:31 AM
megawatt00's Avatar
megawatt00
Adam, John Maximum4x4, lives in Ohio he is a mod in the general diesel forum and a really great guy. Get in touch with him to see if he can help you out.
Old Aug 19, 2009 | 11:00 AM
guzzle92's Avatar
guzzle92
Adam, with your 03 you will have to move the stock tranny cooler or replace it with a 6.0 cooler for the I/C to fit. The oil lines get it the way for it to slide all the way down.
Joe, you have officially been added to the "Whithouse List" of Extremists. Acorn will be watching you.
Old Aug 19, 2009 | 11:41 AM
Izzy351's Avatar
Izzy351
So be it... LMAO!!!! I can take the heat.
And Guzzle is right -- I had to get a 6.0L cooler for mine as well. It's a good mod anyway. You *can* modify the stock cooler if you're froggy. I think Pete did his. Something about cutting & plugging the stock lines, and drilling & tapping the bottom of the cooler so it's fed like the 6.0L type (from the bottom). Maybe Pete will chime in.
Old Aug 19, 2009 | 12:01 PM
brian42's Avatar
brian42
Veteran: Navy
Sorry for the , but I just want to clarify that if I install a 6.0 tranny cooler, then the 6.0 IC becomes a drop-in replacement and there is no inteference to deal with for the IC swap? (That doesn't include the CAC tube boot conversion of course)
Originally Posted by Stewart_H
Ed Zachary!
That's why even with fuel factored into my trip down to Marv's place in SoCal, I feel like I still got a good deal on my IC and trans cooler purchase.
Stewart
Glad to hear you got it okay ! Sorry I didn't check my PM's earlier than I did that day, but I'm glad you got a good deal out of it!
Old Aug 19, 2009 | 12:13 PM
guzzle92's Avatar
guzzle92
That's right.
Old Aug 19, 2009 | 12:14 PM
Izzy351's Avatar
Izzy351
That's correct. The 6.0L cooler is fed from the bottom. The 7.3L cooler is fed from the top and the lines run right where the extra length of the 6.0L I/C needs to be. You will need to make up your own adapters though for the 6.0L cooler. Two short pieces of 1/2" PS hose, about 4' of 3/8ths hose (depending how you run it) and two 1/2" to 3/8ths 90 degree adapters. Here's what mine look like:
I used just enough 1/2" hose so the barbs don't touch. Then run the 3/8ths out towards the engine bay as you lower the cooler down in there. The 90 deg adapters will be turned at a bit of an angle, not parallel or perpendicular to the cooler, if you follow me. Lemme know if you have any more questions. You can click my pick to take you to my webshots account with more.
Old Aug 19, 2009 | 01:14 PM
Stewart_H's Avatar
Stewart_H
No worries my friend.
I missed out on the one you posted.
I ended up finding a deal on a used IC and trans cooler in Hollywood, via Craigslist.
Marv (SpringerPop) lives down in Reseda and he went and met the seller to check the items out. They were in good shape so Marv paid for them and I sent him a check.
I went down to Marv's house the following week and picked up the IC and tranny cooler, getting to meet Marv in the process!
Click on the link in my sig and you'll read the story of how the term The Brotherhood of FTE started because of this transaction!
Stewart
Old Aug 19, 2009 | 06:07 PM
7.3 Rocket's Avatar
7.3 Rocket
You don't need to do any cutting or add any fittings. It'd be a lot easier if you did the trans cooler and intercooler at the same time, but the trans cooler does not need to be modified to allow the intercooler to fit.
Just pop the hard lines for the trans cooler out of their bracket on the passenger side of the engine bay and force them downward. Do not kink them just pry gently. Keep test-fitting the IC until it drops in far enough. I was running around looking for suggestions/input at RRE and Nick was able to do what I described so that I could do the trans cooler at home instead of in TN so I could avoid getting trans fluid on the ground and avoid any possible leaks on an almost 800 mile trip.
Old Aug 19, 2009 | 06:44 PM
Adam0331's Avatar
Adam0331
Thanks for that info Guzzle.
Thanks Jim I appreciate that. I am trying to work out a few other stops along the way. So it won't be a trip just for the cooler, if I do it. I'm still undecided.
Old Aug 20, 2009 | 01:05 AM
big poppa's Avatar
big poppa
Originally Posted by gasgrunt88
I don't know Mike, Adam didn't like my idea of me going out to get it lol.
Don't feel bad, don't think he would like me picking it up either. So far I see a road trip, be a good reason to get that beast out on a great highway run plus get that cooler, awesome price.
Old Aug 20, 2009 | 04:48 AM
  #28
Adam0331's Avatar
Adam0331
I'm pretty sure I'm gonna do it Mike. You coming? Haha, just kidding.
Old Aug 20, 2009 | 06:08 AM
  #29
just another truck's Avatar
just another truck
Adam, if something comes up, best I can tell it is a couple of hours from my place, PM if you need me to try and make arraingments for ya..
Old Aug 20, 2009 | 10:29 AM
  #30
big poppa's Avatar
big poppa
Would be cool, wouldn't it
79schaefer
15
Feb 11, 2017 03:33 PM
fordfan2003
Feb 18, 2016 12:36 PM
cutlass
47
Mar 10, 2015 11:37 AM
dakota joe
Jun 26, 2006 07:07 PM
