Very strange compression problem
Old Aug 18, 2009 | 09:46 AM
FSJNut's Avatar
FSJNut
Bought a 79 F250 Super Cab Camper Special w/400 to keep it from being parted out. It hasn't run in 2 years, but the PO said it was running well when parked. Some fresh gas and a new battery it it sprang back to life --- on half the engine. Passenger side bank (1-4) running strong (125-150 psi compression). Drivers side bank (5-8) not running at all (0 compression on all cylinders.) Leak down test shows all cylinders on the driver's side bank leaking from the exhaust valve. You don't need a listening hose, you can feel the air from the test coming out of the tail pipe!
Removal of valve covers shows all valves moving normally, although there was some moisture under the cover and some tan sludge in the cover. The engine has great oil pressure, warms up and maintains temperature fine, no steam out the tail pipe, oil looks normal,. water looks normal.
I am totally baffled. Again, PO said it "pulled like a tank" when parked. Any ideas?
Old Aug 18, 2009 | 10:14 AM
mustang81's Avatar
mustang81
maby the compression ring are stuck on the piston. I'll removed the spark plug and put diesel on the cylinder for a day.
Old Aug 18, 2009 | 12:55 PM
FSJNut's Avatar
FSJNut
Thanks for the reply. I am pretty sure it's not the rings because a LOT of air is coming out the exhaust pipe when the compressed ir is going in the spark plug hole.
Old Aug 18, 2009 | 12:58 PM
hollenjoe's Avatar
hollenjoe
why dont you pull the bad head? sounds like bad seats...
Old Aug 18, 2009 | 01:03 PM
mustang81's Avatar
mustang81
exhaust valve stay open for some reason ???
Old Aug 18, 2009 | 01:06 PM
mustang81's Avatar
mustang81
sound like a exhaust valve stay open for some reason ???
Old Aug 18, 2009 | 01:12 PM
FSJNut's Avatar
FSJNut
The valves all seem to be moving normally when cranking the motor over with the starter. I pulled a couple of rockers and tapped on the end of the valve stem with a plastic hammer. They sound like they are hitting the seat normally. This has got to be a really BIG leak. When I put the leak down tester hose in the plug hole, there isn't even enough compression to blow my finger off the other end of the hose. In fact , I can't even feel any pressure at all.
I plan on pulling the head this weekend. I'm just trying to figure out what could have caused ALL the cylinders on this bank to lose ALL compression - while the truck was sitting.
Old Aug 18, 2009 | 01:28 PM
mustang81's Avatar
mustang81
Only removed one spark plug at the time when doing compression test. Could be a leak from the head gasket juping from one cylinder to another ? It happend to me with a different motor but it was just with 2 cylinders...removed the head just like hollenjoe said.
Old Aug 18, 2009 | 01:56 PM
FSJNut's Avatar
FSJNut
Compression test was run with all plugs out, throttle wide open, ignition disconnected, approx 5 compression strokes on each cylinder. I've seen gaskets fail and valves burn, but 4 dead cylinders? All on the same bank? I can't figure out what would only affect one bank.
Keep in mind this truck was supposedly running well when parked, now it won't even pull my driveway.
Old Aug 18, 2009 | 02:05 PM
lew52's Avatar
lew52
You will find out when you pull the head off , we would all like to know ... Lew
Old Aug 18, 2009 | 03:08 PM
FSJNut's Avatar
FSJNut
I'll definitely post when I pull the heads. I'm thinking right now that it is an old problem and that it was running this way when parked. Maybe caused by the carb lean on one side. It was also timed early, so maybe the combination took out the exhaust valves?
We'll see . . .
Old Aug 24, 2009 | 12:20 PM
FSJNut's Avatar
FSJNut
Update w/pics
I don't think it was running too well . . .
All 4 cylinders on the 5-8 bank looked about the same..
Old Aug 24, 2009 | 12:44 PM
lew52's Avatar
lew52
Dam thats a nice looking exhaust valve , looks like you need some jb weld LOL , what did the intake on that side look like , i assume is carbrated ..... Lew
Old Aug 24, 2009 | 01:09 PM
hollenjoe's Avatar
hollenjoe
Wow, thats horrible, why dont you pull the other head, and rebuilt them both? Well thats what id do..
Old Aug 24, 2009 | 01:41 PM
FSJNut's Avatar
FSJNut
Plan is to pull the other head tonight and get them both to the machine shop.
Lew, yes it is carburated. I haven't really checked out the intake yet.
Any ideas what I should look for? I don't want this to happen again.
