Question about doing a Dyno run?
Old Aug 17, 2009 | 01:29 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
OK, While at RRE, I did the Dyno. My numbers were 362 HP & 597 TQ. My question is. When starting the run, the operator told me to take my truck out of OD and run up to 60 mph then stump it. At 60 mph, not in OD, I am running 3200 rpm. Would this be a proper Dyno run?
Old Aug 17, 2009 | 01:37 PM
03_PSD's Avatar
03_PSD
Does seem like high rpm's, thought our sweet spot was between 2-3k?
Old Aug 17, 2009 | 03:26 PM
SuperDoodie's Avatar
SuperDoodie
No that is not the proper method. Dyno runs should be done in OD.
Old Aug 17, 2009 | 03:34 PM
miller_feed
Thats what I was thinking. I wonder what the operator was thinking. I guess I was on the back side before I even started the run. That was the first time for a Dyno, so I just listened to what he said. I know that will not happen again.
Old Aug 17, 2009 | 03:45 PM
61 uni's Avatar
61 uni
Did the operator let you run it?
Old Aug 17, 2009 | 03:50 PM
miller_feed
Yes, he stood at the door and told you what to do.
Old Aug 17, 2009 | 04:20 PM
Power_Hungry's Avatar
Power_Hungry
Former ******
For all intents and purposes, ANY dyno run *should* be done with the transmission in a 1:1 gear ratio. This is 4th gear on a 5 speed, 5th gear on a 6 speed, and 3rd (O/D OFF) on a 4R100.
The reason that folks like running O/D is that the increased load helps the turbo spool better and results in slightly better torque numbers, especially on inertia only dynos like the Dyno Jet 248C. Load dynos such as Superflow and Dyno Dynamics can load the truck as much as needed so spooling is not an issue.
Take care.
Old Aug 17, 2009 | 04:32 PM
miller_feed
Take care.
Bill, is starting the run at 3200 rpm the way to do this? That is out of the 7.3 power ban, is it not?
Old Aug 17, 2009 | 04:37 PM
maevans's Avatar
maevans
Take care.
Thanks for the useful infomation. Reps sent.
stroken's Avatar
stroken
I dyno'd both ways.
numbers were higher in O/D but my tires crinkled like dragsters do "said the guy standing at my door at rre telling me what to do" so he made me stop my run, the only thin about doing it in OD is you can run forever!, it will just keep climbing and climbing.
stroken's Avatar
stroken
double post.
Old Aug 17, 2009 | 04:40 PM
Izzy351's Avatar
Izzy351
That's WAAAAY too high to start the run. Here's what my numbers looked like, and you can see the RPM range for yourself:
Old Aug 17, 2009 | 04:45 PM
miller_feed
Thanks Joe, mine starts around 3200 rpm. You can tell on yours that you are starting to go down at 3200 rpm. I wish I would have known better at the time, or was paying more attention.
Old Aug 17, 2009 | 06:25 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
IIRC, you want to start at the bottom of 3rd on all your runs. Basically running the full length of 3rd for your runs.
Old Aug 17, 2009 | 06:43 PM
miller_feed
The OP never said that, he said start at 60 mph and I was at 3200 rpm at that speed. Well, live and learn.
