ipr / crankshaft sensor
Old Aug 17, 2009 | 08:56 AM
snapper021's Avatar
snapper021
Will an injector pressure regulator cause stalling? No start issues?
Does my truck have a crankshaft sensor, I've read that it does not, but I keep seeing where people mention it as a culprit for stalling and no start issues.
early 99 350 psd
Old Aug 17, 2009 | 09:00 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this. click here
Old Aug 17, 2009 | 10:27 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Check out the link miller-feed has in his post. Great info on the cam positioning sensor. As for the IPR, yes it can do what you have suggested. However, it usually acts up when the truck is warm. Will usually idle fine when cold, but idle rough when warmed up. This is caused by oil thinning out when warm and leaking past the o-rings in the IPR. Truck will like to stall at stop lights is a good indicator of this problem. It usually doesn't throw a code when this happens. The truck does usually start right back up though.
snapper021's Avatar
snapper021
i have replaced the cam sensor 4 different times 2 aftermarket and 2 ford since the problem started.
runninbull
Jan 16, 2015 06:50 AM
2006powerstroke90
May 15, 2011 09:15 AM
tlc4
1983 - 2012 Ranger & B-Series
Jul 26, 2007 05:22 PM
wajah2
Aug 19, 2005 07:34 PM
BobFlowers
Apr 18, 2002 10:09 PM
