Fuel pressure gauge
Old Aug 16, 2009 | 08:49 PM
Diesel_Dirk's Avatar
Diesel_Dirk
Fuel pressure gauge
Thinking of how to plumb in my new fuel pressure gauge.
planning on drilling/tapping the large bajo bolt through the head for 1/4 NPT and conneting my hose ther. Or cutting the hard line to the left bank to fit a T inline.
Thoughts?
Old Aug 16, 2009 | 10:41 PM
BlueMule's Avatar
BlueMule
Well to begin with 1/4 NPT is awful large, I'd use 1/8 NPT and instead of drilling and tapping or cutting a hard line I'd either remove the schrader valve from the regulator (1/8 NPT) and put your fitting there or "tee" off one of the fuel return lines that come from the front of the head and go to the front of the pressure regulator.
Old Aug 17, 2009 | 06:58 AM
Neal 97 250's Avatar
Neal 97 250
I would just remove the schrader valve. You may want to consider either an elec gauge or get an isolator so you don't have fuel in the cab.
Old Aug 17, 2009 | 08:09 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
who would be the best to go through to do the electric gauge set up?
Old Aug 17, 2009 | 08:46 AM
Diesel_Dirk
DOH, I meant 1\8 not 1\4
Off the schraeder valve seems obvious mow that you mention it....
and yes, I will use an isolator.
I bought Autometer gauges, isolator is available from them also.
http://www.summitracing.com/parts/ATM-5282/
AlexG21
Mar 2, 2014 07:26 PM
ihandy
Sep 14, 2013 06:37 PM
mickpowell1967
Aug 29, 2010 02:18 PM
TurnerBioDiesel
Jun 21, 2010 02:09 PM
noticon75
Apr 22, 2010 06:37 AM
