strange problem when accelerating under load
Old Aug 13, 2009 | 11:09 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I had problems early last week with the truck running bad, throwing a cel intermittently and stalling when slowing to a stop. I drained the fuel canister, cleaned the fpr screen and new filter which seemed to fix it, which I think may of been water accumulation in the fuel bowl.
Now a different problem started, I pulled our pop up camper up to old orchard maine last saturday and was probably 15 miles from here, out of the 155 mile trip, and it started to sometimes really surge ahead when taking off from a stop but then would cut in and out. By surge I mean feel like it has a lot more power then what it normally has. If I let off and go real easy it would be ok. Even just accelerating quickly with just the truck its self it still is doing it. I am still at the campground here leaving on saturday but would a build up of water do that? It seems to run fine once moving and seems to idle fine? I need to find place to drain the fuel canister agian, hopefully that is it. Maybe the station I filled up at last has a lot of water in their fuel tanks? Any ideas appreciated, thanks.
Old Aug 14, 2009 | 08:23 AM
DRRXR's Avatar
DRRXR
Hmmm
No telling could be a lot of things. I guess you never saw the water in the fuel light come on so I'm thinking its not water. UVCWH may be your issue. How's the oil level? Intermitant surges could also be your fuel pump or even your IPR check to ensure that the IPR doesn't have any bad wires and that the thin set nut is not loose. Just for grins I would add some diesel treat to the fuel and top of the tanks. Let me know what you find.
IPR o-rings could also be a issue.
Here is some reading material.
Rocky
https://www.ford-trucks.com/forums/8...?highlight=uvc
Old Aug 15, 2009 | 12:16 AM
JethroF250's Avatar
JethroF250
by surge do you mean going forward on its own even with the brakes on? if so your tc could be acting up and locking and unlocking. i know when i have mine locked up on the switch it will push through the brakes until it stalls. if the brakes are off it will bog down until up to its desired speed.
Old Aug 15, 2009 | 09:59 PM
oldbird1965's Avatar
oldbird1965
Take a 20oz pop bottle and put it under there, mine would sit right in there and open the value. Its drained and you can also look to see if there is any water in there.
Old Aug 16, 2009 | 09:57 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I got it home yesterday, I didn't have a good place or time to drain the fuel bowl. The strange thing is when the cel comes on, it seems to staighten out for the most part but the transmission shifts hit hard between shifts, but when the cel goes out the truck runs rough and but the transmission shifts smoothly between gears. Also when the cel is off, and taking off from a start feathering the pedal, it cuts in and out but then if I push it quickly to half throttle it will stop cutting out and go. I did notice once when doing that, there was some black smoke on take off, like it was getting too much fuel. And it did stall at a few stops, but will start right back up.
I am going to drain the canister today now that I am at home into a clear bottle to see if I can see any water.
Thanks for the links DRRXR, I will read through those.
JethroF250 what I mean is when I give it some throttle to go I begins like normal but then feels like it gets some extra power from somewhere, wants to accelerate harder, and then this is when it starts to cut in and out.
Old Aug 17, 2009 | 05:17 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I drained the fuel canister into a litter soda bottle but didn't see any water in it yesterday. It did run good for about 25 miles, then it started to act up agian. CEL came on and went back out like it had been doing. The search continiues.
Old Aug 17, 2009 | 06:20 AM
MADVAN's Avatar
MADVAN
Pull the fault codes. It could help find the issue.
On another note its possible your issue is air or fuel volume not water.
Check fuel pressure at idle and under load.
Bill
Old Aug 17, 2009 | 07:36 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I tried to have the codes pulled when in happened the first time but appearntly they were not hard codes, so none were shown to have been saved. The cel comes on and off, so I don't know if the computer would store these or just if the cel stays on. The guy I had check it was using a snap on scanner, so I would assume that would be high enough quality to pull any codes. The only weird thing that showed up was the coolant temp seemed to be off, but I don't remember what it showed.
Seems like I need a scanner hooked up to it as I am driving to catch the code.
Old Aug 17, 2009 | 10:03 AM
CampSpringsJohn's Avatar
CampSpringsJohn
The codes are stored until they are erased. You will likely need to find someone with a scanner that will read these codes. Most scanners at the parts houses don't read the ford trucks properly. Unfortunately at this point all we can do is guess, and you could spend a lot of time and money replacing parts and not fix anything. Cam sensor is a possibility, under valve cover harness, IPR o-rings, let us know what you find out.
Old Aug 17, 2009 | 10:31 AM
MADVAN's Avatar
MADVAN
Remove your 30K mod.
My other wag is a map related issue.
Bill
northwindone
Modular V10 (6.8l)
Dec 4, 2016 05:51 PM
fivo2fst4u
Nov 8, 2015 06:22 PM
parksman
Oct 27, 2013 09:22 PM
hivoltj
63
Mar 29, 2012 06:50 PM
lordmatt
Feb 21, 2012 09:32 PM
