Electrical problem 97 f-350 psd
Old Aug 24, 2009 | 04:01 PM
racenitro's Avatar
racenitro
Thanks Cuda for the Amp value....
I figured it had to be low...
It turns out the bad (Both) batteries was producing false readings....
Had them replaced under warranty and now there is no problem electrical except for the speedometer..
Found the other major problem...Bad Valve Cover Gasket Pigtail...one was completely bare where it passed under the turbo...and the shielding wire (bare) was shorting it out..
Speedometer works up to between 40 and 45 mph...then it jumps and drops to Zero....slow down below 40 and it works again...
Sending unit in rear end or dash module????
Old Aug 24, 2009 | 04:33 PM
Cuda_jim's Avatar
Cuda_jim
Start with the sensor on the rear diff. Clean it off, might just be full of fine shavings, it's magnetic. Check the wiring too. It's not very expensive and available at most auto part stores. Ask for a RABS (Rear Antilock Brake Sensor). If ask for a VSS you will get the wrong part.
gogojuice
Jul 20, 2017 04:21 PM
Rwm8082
Jan 30, 2017 12:39 PM
Corndwg01
Nov 2, 2016 09:12 PM
sprint406
37
Feb 21, 2012 06:25 PM
masterclean5
17
May 18, 2011 11:22 AM
