The correct EGR valve
Old Aug 16, 2009 | 11:31 AM
TheWingnut's Avatar
TheWingnut
I am having no luck finding the correct EGR valve for my 83 I6 300 4.9L 3/4 ton light duty 1brl. My local ford dealer was no help; "if there is no writing on the sticker I can't tell you which one it is". Here is a picture of the one I on the truck, as far as I know it's the one that came with the truck.
the silver thing in the middle of the picture
Old Aug 16, 2009 | 03:10 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You got problems.
There are at least 50 different valves that would fit.
And it's got to be the right one.
The only thing I can suggest is take that one off, go and buy an aftermarket one, like the one you have, (I believe there are two different ones, so that's a 50% chance) and then match the washer on the inside of the valve with one of the washers that come with the new valve. The aftermarket EGR valves are calibrated with washers that you have to press and hammer in, so they can sell 2 or three valves, that fit 50 different applications.
Old Aug 16, 2009 | 07:13 PM
TheWingnut's Avatar
TheWingnut
great!
Old Aug 16, 2009 | 09:37 PM
bashby's Avatar
bashby
I have installed aftermarket units just like the one you have (came from NAPA I believe) It comes with a bunch of washers with different size holes. You look at a charrt that comes with it and take the oem # to pick the proper orfice. If your egr is bad you should be able to go to napa and get one and put the same washer/orfice that you have now
Old Aug 17, 2009 | 07:42 AM
TheWingnut's Avatar
TheWingnut
But BASH there is no OEM number on it, that's the problem.
Old Aug 17, 2009 | 08:27 AM
4caster's Avatar
4caster
81-F-150-Explorer hit the nail on the head, you should be able to visually match the aftermarket washer to the opening on your OEM EGR.
What is wrong with your OEM unit?
Old Aug 17, 2009 | 03:27 PM
Eddiec1564's Avatar
Eddiec1564
Had the same problem on my 84 F250 300, I got a aftermarket EGR and put in the "washer" for my app, it ran like crap. I had to try several "washers" before I got my engine running really good. The one "washer" I used was half sized hole than what they said it needed.
A good parts person should have no problem getting the correct EGR valve, but if possable bring in your old one to compaire, thats what I did....then above fun begins...
86F150302
26
Dec 30, 2016 08:25 PM
jagerbomber
Jul 4, 2012 08:38 AM
Longland
Oct 16, 2011 05:33 PM
Grendelx
Oct 24, 2010 06:50 PM
Blind Tree Frog
1997 - 2003 F150
Dec 15, 2009 10:23 PM
