ACT/ECT testing
Old Aug 16, 2009 | 08:15 AM
geodiggr's Avatar
geodiggr
ACT/ECT testing
Hi all,
Trying to test my sensors this morning. The truck is at ambient temperature, should I still be able to get resistance readings on these two sensors?
If so, by the same token, I should be able to take one out of the box and get resistance readings as well...correct?
Thanks,
Rick
Old Aug 16, 2009 | 09:09 AM
subford's Avatar
subford
Yes you should.
I just checked an ACT sensor and it read about 25,000 ohms.
I will look for my spare ECT sensor but seems to be hiding right now.
The ECT should also read about 25,000 ohms.
Old Aug 16, 2009 | 10:55 AM
Conanski's Avatar
Conanski
See here... http://www.fordfuelinjection.com/
Both these sensors can be tested with a DMM and heated water for the ECT and a hair dryer/heat gun for the ACT, the resistance readings will change as the sensor heats up from ambient.
ExPACamper
Nov 1, 2016 01:51 PM
Jayme Duty
Feb 16, 2011 04:49 PM
milkman22
1983 - 2012 Ranger & B-Series
Apr 21, 2009 08:07 AM
jerzydiver
Nov 5, 2006 10:34 PM
joners
Apr 2, 2006 02:29 PM
