When I come to a stop while in gear aka Drive (It's an auto), my idle surges from 600 to 1000 every 4-5 seconds. Something is wrong as it just starting doing this.
Nothing is wrong. I do believe the defrost runs off the compressor. I would assume even though the fan switch was off, the compressor would still cycle.
There is an idle air controller, and normally it should be able to control the idle extremely well. As they age and get gunked up they do not respond as quickly, causing idle surges. They are about a $45 part at most parts stores. Pretty quick and easy to replace. You can try cleaning it with throttle body cleaner (not carb cleaner) and see if that doesn't help.
sounds like a plan. Question. Where is it located?
